Question about Elite Sl 3000 Ul Sliding Gate Operator
I have al Elite 3000 sl sliding gate opener that is not shutting. When I disconnect the electric power, it closes the gate sometimes half way and it stops, sometimes it closes the gate after one hour
    Problem Solver:
  • 10 Answers
Might also be a issue with the "safety" loop(s), loop detector, loop detector scensativaty frequency, photo cell damaged, photo cell out of aline, faulty or stuck safety edge, faulty receiver, stuck remote control, hold open switch and or timer is set to function or is faulty. Some to none of these may and may not be helpful do to some features listed may not apply to your set up.
Posted on Apr 02, 2016
    Problem Solver:
  • 14 Answers
It does sound like a reversing issue. As on person said, check the track for bumps and obstacles. You might also see if the gate slides smoothly on the guide rollers too. Bumps will often make the sensitivity control reverse the gate. This adjustment is located next to the timer in a tiny blue square potentiometer with a white screw adjuster. Don't turn this too hard. Adjust it in both directions until the problem goes away. Keep in mind you will still need to make sure the obstacles are taken out or it will hit too hard instead of reversing like it is supposed to.
Posted on Nov 08, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Follow the steps in the manual if you have a manual and if you don't have one I recommend that you get one.
Posted on May 09, 2014
4 Suggested Answers
  • 116 Answers
SOURCE: Sliding gate will not close
Check track for obsticles, Does it slide smoothly or does it hand have way and get more difficult, Clean any sensors you can see with a clean rag. Let me know what you find.
Posted on Dec 11, 2008
  • 52 Answers
SOURCE: when should I replace battery for Elite Robo-slide gate opener.
Sounds like its time to replace now!
Posted on Jul 02, 2009
  • 3 Answers
SOURCE: 1. I have an elite slide gate opener it will open
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
Posted on Apr 15, 2010
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
Gate stays open and does not close unless timer switch is turned off
I have a brand new Ramset 300 electric gate opener. My problem is in the early morning when the loop opens the gate it will not close unless deactivated manually. It does not happen later in the day with my GMC truck but happens early in the am with my husbands Toyota Prius. Please help. What can be the problem?
Jun 19, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
1. I have an elite slide gate opener it will open all the way and after a few sec will close. 2. With the remote the gate will not stop and stay in the open position.
Apr 13, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
My elite operator will only close part way, seems to only happen cold nights 52 degrees-F works well in the day time no matter the temperature, limit switches checks out ok, I disconnected the loop...
You will have to increase your force (sensitivity) settings on the p.c. board. Without knowing what type of board you have I can only guess. There should be a pod you can rotate with a screwdriver to increase the force. If it has an LCD readout with menus search the menus for force or obstruction, then increase it.
freddy51
Feb 08, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
My sl 3000 ul gate wont open unless I help it out after i press button on board I have to turn motor shaft and push on gate and then it will catch and opne/close. Is it my motor or my worm gear?
if the motor cant rotate the shaft by itself, its likely a burned coil in the motor, but if the motor is running but not moving the gate then its a broken gear
Jan 24, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Strike open light flashes and gate opens
it was a loose connection on the circuit board in the romote keypad
Sep 30, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Holiday Programming
the elite does not have that function, your are going to need to look for a time clock that holds open your gate...... the outside phone system or a programmable time clock that has been added to your gate...... oh this is an old post sorry. :)
Dec 19, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
The photo eye sensor is defective of is out of its correct posistion!
Hope this was of help!
Dec 11, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Elite Sl 3000 Ul Sliding Gate Operator Logo
526 people viewed this question
Top Elite Home Security Experts
John
jr3261
Are you an Elite Home Security Expert? Answer questions, earn points and help others
