Question about Nikon Coolpix S600 Digital Camera
How can I reset lens error message on Nikon S600
My Nikon cool pix S600 camera showed a lens error message after I dropped the camera. Is there a way to fix it?
t00nz
  • 4738 Answers
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
SOURCE: stuck camera lens
i dont think you can do anything you just have to reffer to a proffessional because there are some gears that maybe damaged
Posted on Nov 01, 2008
welcomejee
  • 10594 Answers
SOURCE: lens error message on nikon
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
Posted on May 01, 2009
  • 736 Answers
SOURCE: I dropped my Nikon Coolpix S600 camera on the
there are some fine gears that move the lens in/out ... if it dropped on the extended lens then its likely a gear was broken or knocked out of place .. it is likely repairable but its really tricky working on these things .. there are fine wires and delecate stuff inside.. sometimes a particle will get into the gears and keep them from operating .. if thats the case you can try gently moving the lens around to try to free it .. but unless you can find someone familiar with working on this then i think you need a new camera ..one with a strap ..
Posted on Aug 01, 2009
caroldon
  • 17129 Answers
SOURCE: Nikon cool pix lens error
Fault in the system controller, failure of the auto lens mechanism, I would suggest that you must take help if the following tip does not work.
Remove battery and keep aside. Tap gently on the lens with the palm, replace battery and repeat this to switch on.
Try this out several times to see if a locked mechanism releases.
Hope this works
Posted on Aug 22, 2010
How do you reset "lens error"
Go to this website for solutions:
Oct 31, 2011 | Nikon Coolpix S600 Digital Camera
Nikon cool pix was dropped with lens out, now jammed and there is a lens error...ANY WAY to fix??? PLEASE HELP
This one is almost assuredly headed for the repair shop, but you might try pulling on the lens a little bit. What has happened is that a gear tooth was skipped because of the impact on the lens, and it is probably cocked to one side. Look at the lens orientation carefully. You might be able to **** it back. Good luck.
Nov 28, 2009 | Nikon COOLPIX L3 Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Lens do not open
try smacking the sides of camera.also try to make the lens up down with you hand couple of times.then check out.
Mar 23, 2009 | Cameras
Ccol pix p4 -showing lens error on the monitor
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Nov 20, 2008 | Nikon COOLPIX P4 Digital Camera
Stuck camera lens
Nov 01, 2008 | Nikon COOLPIX P5000 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon cool pix L11lens error
Remove the battery, wait a couple of minutes, replace battery. (assuming the battery is fully charged. Check there is nothing jammed in the mech. if it still stays stuck.
Dec 30, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix S600 Digital Camera Logo
66 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
