Question about Coby MP620 MP3 Player
Wriggly USB port
Before last night it was fine- the small USB port in the MP3 would accept the wire and connect to the computer. But Last night and tonight, it's extremely loose. I've tried different wires and different computer ports, but it's not working. Any way to fix it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 18 Answers
Typically this is the beginning of the end for your player. However there are some things to try. You can take a pair of pliers and bend ever so slightly as USB cable so that it places pressure on the bottom part of the connection on your MP3 player. I would try this with a cable you don't care for. I wouldn't suggest doing anything with the player. So many users bring my their blackberries that have the same issue. Most users do not come back to see me for quite a while or until the device is dead. These devices require tight connections, the only other option is pressure and that is what bending the plug does. Lastly, notice the two little notches that come from the wider side of the metal part of the USB connection. Are they protruding up even slightly? That may tell you something is wrong with your USB cables.
Posted on May 09, 2014
Coby MP3 USB port loose and wriggly?
If you know anyone who can solder surface mounted parts they can probably solder it back. Sounds like usb connecter has come loose from the circuit board.
May 09, 2014 | Coby MP-C582 MP3 Player
My photos won't transfer to my computer. The the last time I loaded photos onto my computer which was last week, it worked fine. however today the same computer says it does not recognize the USB device,...
Change the USB port. If you are connecting it to front USB of your computer, try connecting it to USB port at back of computer..
The cable might be fauty.
Apr 11, 2011 | Kodak EasyShare C330 Digital Camera
I just got a new mouse, and last night when I
try to do these things:
1. press the black link button on your puck or key that connects to the PC usb port.
2. turn the only switch on the bottom to ON (to the right)
3. press the link button on your mouse on the underside.
4. double left click your mouse to make sure it will wake up and run
5. check it on another USB port
6. look for damaged pins in your usb port on the laptop
Sep 24, 2009 | GE Wireless Optical Mouse
Computer wont recognize my e book...it was working fine last nigh
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 30, 2009 | Western Digital My Book Home 320GB...
Turns on, but won't go beyond 'initializing'..
Sounds like their may be some type of firmware corruption. Visit the website:
www.rcaaudiovideo.com
and follow the linkes to find your version of mp3 player, download the latest firmware and install it.
Aug 08, 2009 | RCA M4208 MP3 Player
Ipod will not accept the charge
You can try to use a other usb port on you computer or try a other computer. It is posible that you have a broken cable so try a other one :) and a last tip: reset you iPod :) put hold on and off en push menu and the select button for 10 sec.
Jul 16, 2009 | Apple iPod classic MP3 Player
My ipod is showing the apple sign and wont turn on
Hi, So 1st connect your ipod to your computer USB port ( Desktop computer at the rear USB port ) Then try these steps
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 10, 2009 | Apple iPod MA446LL/A MP3 Player
My sansa is spazzing out
Go to settings - USB Mode -- msd; and make sure the port on your computer is a USB 2.0 port.
Jul 05, 2008 | SanDisk Sansa e250 MP3 Player
E280 not charging
You might have to get a new charger--But be careful. If the charger isn't made especially for the Sansa e280 there's the possibility of it messing up the mp3 player itself.
It could also be your computer's USB port. Try using a friend's computer or a different USB port perhaps and see if it works then.
Apr 07, 2008 | SanDisk Sansa E280 MP3 Player
Coby MP620 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
