Question about Briggs & Stratton Electrical Supplies
Im looking for a genarator serial no.1013779540
I'm looking for information on a briggs and Stratton generator with the serial no. 1013779540. I know it is a 10hp and a Power product group llc.
5 Suggested Answers
FRANKSFIXIT
  • 72 Answers
SOURCE: Coleman Powermate 6250 generator
My answer:
You will need to contact Powermate directly (see below), and give themthe CORRECT model # info that you have there on that Genset.
Unfortunately what you posted above doesn't help out at all as there isNO model # for reference. Certain models are no longer available asthey have been discontinued and only by contacting Powermate directlywill you get the proper Operators Manual.
There should be no charge for this and most likely it will be a PDF download sent by their service dept.
The model # should be found either on the engine decal plate or else on the generator head assy or it's power panel.
Please post me a reply as to finding this solution being the bestresolve to your missing Operators Manual problem by following thecompany references & links below. Also please rate mytroubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Customer Service: US: 1-800-445-1805 Mexico: 011-52-5553-660800 Canada: 1-877-501-0090 Technical Service: 1-800-445-1805 or Email: At productservice@powermate.com and a service representative will personally respond to your inquiry Service Centers: Click here to find your nearest service center in the US or Canada FAQs: Click here to find answers to our Frequently Asked Questions Product Manuals and Parts Diagrams: Click here to find your product manual or parts diagram Register your product: Click here to register your product.
Posted on Sep 05, 2008
  • 197 Answers
SOURCE: I'm looking for the 2 cycle oil to gas dilution
20:1 that's 1/4 pint to a full tank of fuel.
Posted on Jan 17, 2010
jerome42
  • 30 Answers
SOURCE: I'm looking for a free
Try this link
Posted on May 04, 2011
SOURCE: Briggs and Stratton GenPower 11 generator cover plate ???
I have a Briggs & Stratton GENPOWER 11 generator that is electric start. The electric start will not start the motor or ever turn it over. I can turn the key on and jump across the terminals on the starter and it will run only if I continue to squirt starter fluid in the carb. My question is, if the ignition switch is bad, could that be the reason it will not stay running. My only guess is if the ignition switch is bad, the motor thinks it is in the off position at all times. Thanks, R Ray
Posted on Nov 23, 2011
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
The genarator if there is one regular? gives no pover to the battery
it generates less than 9 amps. they don't need a regulator to control voltage. some generate ac and dc current... for charging the battery is dc and running the headlights is ac
Aug 20, 2013 | Briggs & Stratton Garden
I am trying to figuare out what type of oil to put in a Briggs & Stratton model 09415-0 generator
Hi b_fesperman,
Here is Briggs&Stratton's webpage with the oil specs for their engines: http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Engine%20Oil%20Recommendations/
Copy and paste the entire address into your browser and the information will open for you. Note that synthetic 5W30 can be used in all temps.
Hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Jun 08, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Jul 16, 2010 | Coleman Powermate Premium Plus 6250W...
No power output from Briggs & Stratton ProMax 7500E generator
You may have exciting field broken. Look for a fuse or wire break.
Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
Where do i get a coil at?
Well, if Briggs and Stratton engine, then try briggs and stratton.
If Robin / Subaru engine, try there.
Write down the model type and serial numbers, then pay a visit to local small engine repair shop and have them order for you.
Dec 21, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
21 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
