Question about Radio Communications
My picture is so dark you can`t see it
Went to watch T.V. and the picture is so dark you can`t see it. The sound is great. I have tried adjust it and nothing happens. It worked earlier that day. It doesn`t get used except when the grandchildren are over so it is like new
  • linda tucker
    linda tucker May 12, 2014
    The picture is so dark use can`t use menu to try and adjust it. you can shine a flash light on the screen and you can barely see there is something on there but it is to dark to watch
SOURCE: Hitachi 50in. Ultravision Model #50ux14b
Vertical output chip has some ring cracks on leads (cold solder joints). Set is shutting brightness off to protect5 it's crts from burning a black streak across them.
Posted on Oct 03, 2007
markevans
  • 148 Answers
SOURCE: CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Posted on Dec 24, 2007
SOURCE: Monitor dark PRoview PL916s
try to contact an expert technician of monitor maybe there is a part of your monitor that is already defective, the controller of brightness and contrast.
Posted on Feb 20, 2008
  • 362 Answers
SOURCE: Sony Bravia LCD KDL32M3000 picture going dark
Sounds like it may be the backlight ballast on the inverter. Hopefully you are still under warranty, Call customer support even if you are out of warranty and explain problem. In English: 1-800-222-7669 or 1-888-772-7669
Hours: Mon-Fri 8:00AM-12:00AM (Midnight) / Sat-Sun 9:00AM-8:00PM EST
In Spanish: 1-800-222-7669 - Follow the (English) voice path for your product, and then select the option for Spanish support
Hours: Mon-Fri 9:00AM-10:00PM / Sat 10:30AM-7:15PM EST
If they can't help let me know and we can diagnose the problem together. Let me know if this helps and please rate this solution. LOne99star
Posted on Jan 17, 2009
  • 56 Answers
SOURCE: Turns on But No Picture and No Sound
sounds like it could be a cabling issue, try replacing the cabling (if you have another tv, you can borrow the cabling before purchasing new set of cabling)
Posted on Apr 04, 2009
Why is my TV picture dim
Hello David
It sounds that the back light inverter board, and back light CCFL lamps to your TV need to be checked. It will be best to contact any service technician, because to check its back light CCFL lamps, you must disassemble the display panel, a very skilled work indeed. If you are sound in electronics, you can check it. If you wish to know more http://electronicshelponline.blogspot.com/ check this link. It has details. Pull up older posts there by its left side bar, or see it in 'Timeslide' option.
Jun 18, 2013 | Sanyo Dp55441 TV
DARK PICTURE
Just restart the tv and can u tell me company name and model no.........
Aug 03, 2008 | Toshiba 42H83 42" Rear Projection...
The screan is too dark while I am watching tv
If a conventional picture tube type set it will have a high voltage transformer inside with a focus and "screen" control--in this case the screen needs to be adjusted up slightly.
Adjustment is inside the set so you have to have back off and be careful as high voltage is present when set is on (need it on to adjust the screen control just up a tiny bit).
Oct 21, 2012 | Orion STV2763 27" TV
Apr 04, 2009 | LG 50PC5D Television
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
Why has the picture on my tv gone too dark to
have sound but picture is too dark to watch on tv
Mar 21, 2009 | Televison & Video
My new 400D with kit lens produces dark pictures. I tried everyth
take it back and get it replaced sound like your shutter Assembly went out.
Jan 06, 2009 | Canon Digital Rebel / EOS-300D Digital...
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
RCA P46130 no picture
i tried unplugging mine when the picture went out. i left it unplugged for about 10 to 15 minutes. still no picture
Jan 10, 2008 | Philips 50P8341 50" Rear Projection...
Radio Communications Logo
14 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
