Question about Skil 3.6V iXO Screwdriver
Black decker screw driver not charging - Skil 3.6V iXO Screwdriver
Why wont my black and decker 7.2 lithium drill take a charge ?
Did you check if the battery holds the charge? Also, you should verify the charger's output with a voltimeter.
Oct 26, 2015 | Black and Decker USA Black & Decker...
How do I re-charge by Black & Decker 12v cordless drill?
If it is a Ni-CD / NI-Mh battery, please fully discharged and fully charged it to prevent "Memory effect".
If it is a Li-ion battery, please charge it before you use it.
Please keep in mind that, please fully charge a battery when you store it. And, charge it again every two months.
Oct 04, 2014 | Black & Decker 12v Cordless Drill/driver...
How do you know when a black and decker battery's life is over
Normally when it will no longer hold a charge, that is, no matter how long you charge it, the battery goes flat very quickly. This happens sooner with Ni-Cad batteries than with Li-Ion.
Nov 19, 2011 | Black & Decker 18 Volt Cordless Drill...
Black & Decker cordless drill...how do i know it is charging? I am not sure i have the correct charger.
There are light on chargers, some red some green, red means chargeing, green mean charged.
Jan 17, 2011 | Black & Decker 18V Cordless Drill/Driver
How do I change the screw drivers on the black & decker power screw driver?
The black collar should slide forward, allowing for the removal and insertion of bits.
Nov 25, 2010 | Black & Decker Pivot Plus Cordless...
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
How do replace a chuck on a black-decker cordless drill
you must open the chuck all the way and the screw is in the back inside the chuck this is a left screw which means its righty loosey and lefty tighty; unlike normal righty tighty and lefty loosey.
Mar 29, 2010 | Black & Decker 18 Volt Cordless Drill...
I wanted to know how long I should charge my battery black and decker 12.2 impact driver
hi, usually about 1 or 2 hours, overnight for a full cahrge, but depends on battery condition, hope this helps
Jan 19, 2009 | Black & Decker Black and Decker Cd9602k...
Skil 3.6V iXO Screwdriver Logo
35 people viewed this question
Top Skil Drills Experts
epangan29
Are you a Skil Drill Expert? Answer questions, earn points and help others
