Question about GE Refrigerators
Model TFA27R doors out of alignment; top of refrigerator door must be moved to right as it rubs against freezer door at top. How do I adjust doors?
Slotted screw on top of door, under a cover, needs to be loosened, adjust the door, tighten. That's it.
Posted on Jun 23, 2009
Right door flap not hugging door when ioening left door with right door already open
The doors have to be adjusted. They may have moved out of their intended alignment over time
May 01, 2013 | Frigidaire FGHG2344MF Bottom Freezer...
Door alignment on Amana bottom-freezer refrigerator
what you need is a new Hinge, Rh Top-e Ct. part number 12077319
Jan 10, 2013 | Refrigerators
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer and refrigerator doors are mis aligned after move. gaps where you can see into both compartments. are doors adjustable to fix this problem?
can you see the rubber gasket which will be fixed all the four sides of the door,it should be uniform when you close the door.
Jul 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Refrigerator top freezer door slightly rubs to inside freezer bottom while closing the door that opens on right side. Due to this after closing the freezer door, the door opens less than a mm near the left...
I think I can help. Usuly the doors have been swapped around in this case. look closely at the freezer door on hinge side. there should be a small metal piece that covers the hinge to prevent anything from jamming hinge. this shield also serves as a spacer. this is what sets the door at the correct height. if the piece is missing you can have your local appliance dealer order one for you. it only takes a few minutes ts to install. you will need to remove the freezer door to do this. Hope this helps and good luck.
May 07, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
My bottom freezer door isn't aligned right the
Don't think buildup is the problem. Sometimes the doors become loose and need adjustment.1a4bfab.gif See if you can locate the model serial number so I can help you better, Sea Breeze
Mar 27, 2009 | Maytag MFF2557HE Bottom Freezer French...
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
