Question about Clymer Evinrude/johnson 2-40 Hp Outboards includes Electric Motors 197
No water flowing out my 40hp envenrude outboard water exaust port
Start my outboard but there is no water coming out water exhaust port
    Scholar:
  • 126 Answers
Plossibly clogged intakes (grim in intakes) or thermostats not opening. I would suggest pulling the lower unit and then your thermostat housing and use a water hose to back-flush it out. Also check the thermostats in boiling water to make certain opening.
Posted on May 09, 2014
Omc I/O, V8 engine overheating, garden hose supplying water, no water coming out the exaust.
Check if the water is flowing to and thru the engine. disconnect the hoses between thermostat house ( upper front of the engine ) and the exhaust manifolds.
If you have water there, then replace both exhaust manifoldes AND risers...
Aug 31, 2017 | Boating
4ohrp mercery outboard over heats
water pump impeller failure check tell water outlet for flow
blocked water inlet holes
corroded plate in the block between coolant and exhaust allowing exhaust gas into the coolant
corroded cylinders
May 28, 2017 | Boating
85 40hp evinrude stuck in forward?
Evinrude used a shift mechanism located in the lower unit that is actuated by a rod up to the linkage in the motor housing. It could be stuck anywhere along the way or the gear that shifts on the shaft could be immobile due to rust and corrosion.
You may want to find a blowup of your exact model via a Google search. Then starting from the top look for your problem. be sure to mark the position of anything adjustable so you can at least get it back to the original position when you reassemble it.
Find 1985 40hp Johnson Evinrude Outboard Motor Parts by Model Number
Feb 06, 2015 | Light Outboard Motor Boat Bass Fishing...
How to install a evenrude outboard water pump
the exhaust ports start from the side of the engine block 2hp -90hp then v4 and v6 and v8 are between the v blocks ! from there they go down the leg unit , top rear of leg have an outlet for tickover then the main outlet is either through the prop or above it on small or old type engines !
May 09, 2014 | Boating
Yamaha outboard water pump
sounds like you blew a gasket . find a dealer .
Jun 26, 2013 | Boating
Outboard motor
Check that there are no cracks in the fuel lines, check the wiring harnesses under the hood for wear caused from rubbing against the hood or components hope this helps you out.
May 07, 2013 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Clymer Evinrude/johnson 2-40 Hp Outboards includes Electric Motors 197 Logo
506 people viewed this question
Top Clymer Plumbing Experts
Donni Steen
Tom Chichester
Are you a Clymer Plumbing Expert? Answer questions, earn points and help others
