Question about Kyocera FS-C5015N Laser Printer
Ep Not supported
I recently gave my Kyocera Ecosys FS-C5015N a clean because there was a lot of toner dust flying around inside. When I have done this in the past I haven't had any problems. however, this time when I plugged it all back in It's showing on the screen 'EP Not Supported'. I cannot press any of the buttons to find out more info either???
  • Ama tr
    Ama tr May 09, 2014
    It says, EF not supported, Sorry I miss read it.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 142 Answers
This could be a false detection of the "Envelope Feeder".
Apparently this optional accessory exists for the FS-C5025, not for the FS-C015.
If you run a google search for "Kyocera EF-310" and select the images section you will see how it looks and where it gets installed.
My guess is that something happened from the cleaning process, so that the printer "thinks" an envelope feeder is installed.
I hope this may help.
Posted on May 09, 2014
  • 25 Answers
SOURCE: problem with EcoSys Kyocera FS2000D
that is a fuser code check the fuse
Posted on Dec 31, 2008
leroyal
  • 2120 Answers
SOURCE: printing all pages as black
Open up the left side door and push in all of the chargers to make sure they are seated.
Posted on Jan 17, 2009
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
  • 66 Answers
SOURCE: Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Posted on Sep 20, 2009
don_farr
  • 1011 Answers
SOURCE: how do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Posted on Nov 19, 2009
Toner on the back of copy
unit dumping toner or developer. usually caused by using non OEM supplies. have unit cleaned and use kyocera supplies
Jan 15, 2016 | Kyocera Ecosys FS-6525MFP Laser...
Waiste toner box full.....how do I clean or change this? Looked through owners manual and can't find anything about it.
The waste toner sensor has detected
that the waste toner reservoir (drum unit)
is full.
FS 1128 has drum and developer as separate unit, waste toner gets collected in the drum unit . Right or left side of the drum unit has a cap fasted with screw, open it and remove the waste toner.Refix the drum and this will solve the probelm
Oct 08, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
HOW DO I CLEAN MY KYOCERA FS-2020 ECOSYS MONOCHROME LASER 35 PPM
Cleaning the Printer
To avoid print quality problems, the interior of the printer must be
cleaned with every toner container replacement.
1 Open the top cover and MP tray.
2 Lift the developer unit together with the toner container out of the
printer.
3 Use a lint free cloth to clean dust and dirt away from the registration
roller (metal).
4 Insert the developer unit together with the toner container, back into
the machine.
5 Close the top cover and MP tray.
6 Open the left cover. Use a lint free cloth to clean dust and dirt away
from the vents.
7 Close the left cover.
8 Use a lint free cloth to clean dust and dirt away from the vent on the
right side of the machine.
I hope this is helpful,
Shawn
Jan 25, 2011 | Kyocera FS2020D ECOSYS Monochrome Laser ...
My kyocera FS-C5015N printer is printing all my pages with blue background, also get alot of paper jams
Reclean the cyan corona wire/grid with the cleaning block that comes with each toner.ensure that you leave the corona unit as far out of the machine as possible for 30 seconds to allow the grid to dry.If this does not work then you will need a technician to attend to the printer.
Jul 29, 2010 | Kyocera FS-C5015N Laser Printer
Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Jan 24, 2010 | Kyocera FS-C5015N Laser Printer
How do you clean dried toner from colour developer units
Kyocera toner for the FS-C5015N is dry. If you have excess toner outside the developer use the cleaning cloth that comes with the toner kit.
Do not wipe the magnetic roller at the bottom of the developer. Along with the toner, the agent is on the roller. If the agent is removed the toner will fall out of the developer. There is agent in the toner container but not enough to replenish all of it if it has been wiped away.
Nov 14, 2009 | Kyocera FS-C5015N Laser Printer
it is not too late
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Problems after replacing toner
You should just have to press the "GO" button to tell the printer that cleaning is complete and the printer will then carry on working once the toner has been added.
Feb 19, 2009 | Kyocera FS-C5015N Laser Printer
Printing all pages as black
Jan 17, 2009 | Kyocera FS-C5015N Laser Printer
Kyocera FS-C5015N Laser Printer Logo
95 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
