Question about Brother MFC-465CN InkJet Printer
HOW TO FIX BROTHER MFC- 7470D 'UNABLE PRINT EF'?
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
cene765
  • 787 Answers
SOURCE: unable to clean print heads
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 24, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: Unable to Clean 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Brother MFC 7470D
you can use reset gear with follow structure:
http://reset.vn/reset-hop-muc-may-in-brother-mfc-7470d.html
May 20, 2012 | Brother MFC-7440N Laser Printer
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Unable to print error code 4f. How do I fix?
unable to print 4F
BROTHER mfc-465cn. What is the problem and how doI fix it?
Jul 06, 2010 | Brother MFC-465CN InkJet Printer
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Help
I say you throw it in the trash
Sep 23, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-465CN InkJet Printer Logo
192 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
