Question about KitchenAid KEBC107 Electric Single Oven
KERC506HBS3 Recently, our oven and broiler has stopped working. The stove cooktop works and is fine but nothing heats up in the oven. All I can find as to the problem is it could be the motherboard or possibly a thermal fuse. A motherboard sure seems like the expensive route but as far as the thermal fuse, I'm not sure what one I'm looking for. Thanks for your help.
    Sergeant:
    Champion:
  • 214 Answers
One thing I've run across is that the heater leads burn off the terminals inside the oven cabinent.
Posted on May 09, 2014
5 Suggested Answers
  • 1314 Answers
SOURCE: kitchen aid wall oven kebs177dssp
call whirlpool tecnical assitance see if they have a kit for it tech knows parts people dont most of time they do beleive or not they want it to work right been working for the factories for years and they doo care
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Macmarkus
  • 2605 Answers
SOURCE: I have a Kitchenaid gas
Welcome to FixYa.
Based on your description I suspect you have a faulty bake ignitor. This may surprise you, or it may not. I think at first it surprises people when the hot surface ignitor glows but the oven either will lite but go out shortly after or won't lite at all.
Since the ignitor "glows" one figures it would appear to be working, that would be wrong. These ignitor's serve 2 functions, first it need's to maintain a set value to open/activate the gas valve, typically around 3.5amps... & 2nd Ignite the fuel once said valve is open.
A poor/faulty ignitor may glow & and even ignite the burner intermittently for moments at a time ( thus giving off some heat but never the set amount or not at all ) but yet not reach the needed value to open the valve consistently nor adequately, hence the need to replace the bake ignitor.
Try this ( replacing the hot surface ignitor ) and I'm certain you'll be up & running and as they say " cookin' with gas" !
**Be sure to unplug the range and turn off the gas before performing any service to the unit...safety first**
I`d also suggest you try the oven on just "broil" as well to insure that ignitor is ok. The top ( broil ignitor ) is the exact same, so you can swap them around as a test to confirm indeed the bake ignitor is faulty..or not.
Here's a helpful link to help check and diagnos the hot surface ignitor, it will varify exactly what I've explained...
http://www.youtube.com/watch?v=M02AIkraWH0&feature=player_embedded
You should refer to your specific model when ordering the part locally or on-line. The most common hot surface ignitor part is #12400035 (see image ) and it pretty much fits everything, but your ignitor is 9753108 by my search.
Either one is made by "Norton" as most are. The first is a Maytag/Magic Chef part number, the second ( yours ) is Whirlpool which is the manufacturer of your Kitchen Aid.
Try places like repairclinic.com, searspartsdirect.com, appliancepartspros.com etc.
Thanks for visiting "fixya", let me know if you require further assistance and good luck.
Regards,
Macmarkus :)
Posted on Oct 19, 2010
SOURCE: KEMC308KSS04 Micro/Oven combo is not heating. The
sir i am using 800W LG micro oven, by using that what is the maximum temperature i can get,,,,,,,,,,,
Posted on Mar 28, 2011
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
Oven dosen't heat up.
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at http://appliancehelponline.com/ovenelementvideo.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Jun 08, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore electric oven will not heat, broiler and stove work fine
I also have the exact same problem, is ther a possible fix-it-yourself solution for this???????????? if not what should a repair cost?????
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
KitchenAid KEBC107 Electric Single Oven Logo
67 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
