Question about Lexmark X8350 All-In-One InkJet Printer
Lexmark X8350 ocr - Lexmark X8350 All-In-One InkJet Printer
5 Suggested Answers
SOURCE:
preachw996
  • 1179 Answers
SOURCE: cant find disc to install printer to computer lexmark x8350
Go to the Lexmark website. Click on the support link; lookup your specific model # and select the operating system you are running. The software/drivers will be listed for free download. Download, install, and reboot and you should be all set. Hope this helps.
Posted on Aug 26, 2009
  • 12 Answers
SOURCE: Where I can find OCR Sofyware CD for Lexmark X8350
Or just get yourself an additional OCR software. More information is available at http://www.ocrworld.com
Posted on Jul 18, 2010
  • 77 Answers
SOURCE: Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Posted on Sep 08, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: ocr software for lexmark x8350
    The Lexmark OCR scan software can only be installed using the install disc that came with your Lexmark printer. If you lost it, I'd suggest you contact Lexmark technical support for assistance.
    Posted on May 03, 2011
    I am trying to scan a doc, but don't know how to set up the scanner. I am running MS office 2007 on XP- OS
    Make sure the Lexmark OCR scan software (used for scanning documents for editing) is installed on your computer. The scan software is available only on the installation disc that came with your printer. No downloadable driver is available in the Lexmark website. Just insert the install disc into your hard drive to install the additional software on your computer.
    Jul 27, 2011 | Lexmark X8350 InkJet Printer
    When I scan a file to pdf and save it.....I can't get it to upload
    Make sure the Lexmark OCR scan software is installed on your computer. The scan software can be downloaded using only the installation disc that came with your Lexmark printer. Just insert the disc into your computer hard drive and execute the file. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
    Jul 25, 2011 | Lexmark X8350 InkJet Printer
    I NEED THE OCR SOFTWARE TO BE ABLE TO SCAN DOCUMENTS- PLS HELP..I CANNOT FIND THE ORG DISK.THANKS
    You can download a copy of the original software that came with the printer on their website located at www.lexmark.com. Click on support and then download drivers/software. Enter your make and model of your printer and click on the software that you wish to install. Follow the prompts to download and install it and you should be good to go!
    Jul 12, 2011 | Lexmark X8350 All-In-One InkJet Printer
    Can't get the scanner to work
    Check if it's a hardware, software or a USB connection problem.
    If you are able to make a copy using the Copy button on the printer operator panel, then hardware is good.
    Try to disconnect and reconnect the printer into your computer.
    Then send a print job. If print job is sent successfully, then USB connection is good.
    Try to update your printer driver by reinstalling the printer software. If you are scanning a document for editing, make sure the Lexmark OCR scan software is installed on your computer. The scan software is avialable only on the installation disc that came with your printer.
    If problem continues, please contact Lexmark Technical Support Center to further troubleshoot this problem.
    Jul 06, 2011 | Lexmark X8350 InkJet Printer
    Once a doc is scanned on a 8300 series all in one, how do I get the scanned image from the printer to a word doc? Looked
    You can actually scan directly to an application(ex. MS Word application). Also, make sure the Lexmark OCR scan software is installed on your computer (the software is available on the install disc that came with your printer).
    1. Load an original document into the ADF or on the scanner glass. 2. Press Scan Mode. 3. Press ? or ? repeatedly until the MS Word application is highlighted. 4. Press check button. 5. Press Start Color or Start Black to start scanning.
    Source: Lexmark 8300 Series User's Guide page 72.
    May 14, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
    Ocr software for lexmark x8350
    Apr 04, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
    No cd
    You can download the Lexmark X8350 driver from the Lexmark website for free. Note: Lexmark X8350 works on Windows operating system only. Use Vista driver on Windows 7.
    Go to this link Lexmark X8350 Drivers. Select your operating system version by clicking on change OS.
    Click on FILTER.
    Then click on Complete Driver under Recommended Downloads.
    Download, execute the file and follow the instructions on the software.
    I hope this information has been helpful. Thanks.
    Dec 15, 2010 | Lexmark X8350 All-In-One InkJet Printer
    Lexmark 5600 how can a I scan or make it a word document or pdf file
    You will need the Lexmark OCR scan software to scan a document from the printer to your computer and save the file as PDF, word document, etc. The Lexmark OCR scan software is only available in the installation disk. If you don't have the disk or you lost it, contact Lexmark technical support to request for it. Thank you for choosing Lexmark.
    Sep 14, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
    The Lexmark OCR software can only be installed using the installation cd that came with the printer. If you don't have it or you lost it, you can request one by contacting Lexmark Technical Support. Hope this helps.
    Jul 16, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
    Lexmark X8350 All-In-One InkJet Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Clive
    Clive
    Thomas F. Schneider
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
