Question about Samsung Televison & Video
55" flat screen tv has black around the picture and will not let me zoom out
    Problem Solver:
  • 6 Answers
Is his the case wen watching dvd and cable or sat box? If so do reset from picture menu. if only cable or sat box then try zoom or pic size on cable or sat remote.
Posted on May 12, 2014
SOURCE: Picture issue
It's not the TV it's the source( check settings in your DVD player or cable box
Posted on Dec 09, 2007
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Posted on Mar 03, 2008
  • 280 Answers
SOURCE: the rca tv will not power up 55 inch
Is it a rear projection set? or LCD? If it is a projection set it could be a bad High voltage splitter. Part is about $30 If it is LCD it could be a bad power supply or inverter board. A good tech can replace capacitors in power supply without replacing the board
Posted on Mar 13, 2009
westytech
  • 120 Answers
SOURCE: 32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Posted on Feb 04, 2010
  • 15 Answers
SOURCE: Picture Is Too Big for Screen
Sounds like your cable box is zoomed in, I run into this a lot when running service calls. On most cable provider's remotes there is an 'aspect' button next to or around the '0'. Try that and see if it helps you out at all :)
Posted on Feb 24, 2010
Why will my picture not fit on the Lg 5100 led tv?
look up your instruction book and get the menu up on the screen . . will be a thing in there for the screen size . . make sure it is set on correct size
Jun 01, 2014 | LG 55LN5100 55" LED TV 1920x1080, 120 Hz,...
Pictuer hight
Use the zoom function on the remote. Be advised that all programs you see on TV will not fill the screen completely because they are a different resolution. The TV handles it by putting black areas around the picture so the aspect ratio isn't changed.
Mar 23, 2014 | Sharp AQUOS LC19DV28UT 19-Inch LCD TV/ DVD...
Why is the picture bigger than the screen?
Check the picture settings. If picture is zoomed, the effect will be like this.
Mar 21, 2013 | Vizio M550NV 55 in LCD HDTV
Hello, pretty simple probably. How do I use the entire screen for the picture, I can hardly read the news scrolls that come at the bottom of the screen cuz of the 3 inches of black border all the way...
No.Some u can't changes the tv picture on the screen sizes,because depending the bandwith of ur tv are recieving.Most u can changes the tv on picture to wider screen or to fit the whole tv screen.U have the tv original remote wright?Yes.Look a button that said like Viewmode,Aspect Ratio,Picture sizes,Zoomming.Pushes one of these name buttons u will able to changes tv on screen pictures sizes.
Aug 23, 2011 | Vizio 42 in. LCD TV
How do i ajust the picture size to fit the tv?
get the remote... go to menu...roll through to you come to picture / set up here you should see zoom1, zoom 2, normal, wide and panaramic... (note that some shows broadcast in wide screen) top & bottom is cut off...and in hi def the box (picture is showing like a box) all around is black out...don't feel bad I have 56 inch hi def and get mad.... i have 4inches all around all black out if i wanted a 48 .....
just enjoy it Season Greetings
Dec 26, 2010 | Philips 32PF5531D 32 in. LCD Television
The picture on my new 55" lcd hdtv overlaps the
Find a buttons on ur tv remote control that said like VIEWMODE,P.size or a Zoom.Push one of these buttons to find the wright picture mode to fit in ur tv picture screen frame.
Nov 22, 2010 | Vizio VF550M 55 in. LCD HDTV
Feb 24, 2010 | Samsung LN55B650 55 in. LCD HDTV
How to make the picture be on the whole screen
Just try to ZOOM IN the screen of you TV, by pressing the zoom option of the remote or going to picture options in the Tv menu. This affect the picture you get but makes it bigger!
May 10, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Picture issue
Nov 22, 2007 | Hitachi 55HDS69 55 in. Plasma Television
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
