Question about Baby Lock Sewing Machines
Grinding sound I accidentally lowered the needle onto the presser foot before moving the needle to the center position. I was able to get it to release and turn on, but now there is a grating/grinding sound when stitching. It does stitch, but the sound is awful.
  • Baby Lock Master
  • 662 Answers
Did you replace the needle? Look at the hole in the plate and see if the sides are rough. If they are you may be able to cure them with your finger nail file. There is a hook under the plate that rotates or at least goes half way around. Remove this and check for marks that are rough, especially around the sharp end. If you find them you might be able to save it with some sand paper. Make sure you blow this area out and put a drop of sewing machine oil on the race (where the hook came from). Do all of these. If there is still a problem the needle arm may have gotten bent. Do all of these and you may save it yourself. Do one other thing. If your hook is too rough you can order a new one through the internet for about $ 25. You will only need the brand of sewing machine and model. Hope it works.
Posted on May 09, 2014
  • 46 Answers
SOURCE: Centered needle won't stitch
Timing is not correct.
Posted on Aug 05, 2009
  • 46 Answers
SOURCE: needle position
perhaps the needle is not in straight or is bent.
Posted on Oct 24, 2008
abhishek33
  • 1239 Answers
SOURCE: needle locked in right position
hi . The lock has a clamp arm which receives a threaded fastener and a needle tube arm which has a bore which receives the needle tab. The arms are integrally formed from stainless steel or other suitable sterilizable material. The lock is positioned about the needle tube and may be rotated relative to the needle tube retainer to a selected position and secured by tightening the fastener against the retainer. In this way, the tattoo machine is usable even if the retainer is broken or damaged.
Posted on Sep 13, 2008
  • 1116 Answers
SOURCE: Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Posted on Feb 22, 2010
  • 517 Answers
SOURCE: I live in Ecuador. I
Good day!!!
If your screen stated"main motor blocked" then I suggest you remove the thread,both the top and the bottom.Please change the needle too.but If the problem is unsolved,kindly loosen or unscrew the casing which is in the front of the bobbin, then look/find anything that might be obstructing the bobbin. check again the thread, bobbin and needle.Also for the last thing put an oil to the parts which you think it needs it like the moving parts re-start or reboot it then leave for a whole night.
Thank you and good luck...
Posted on Jul 22, 2011
How do you use the buttonhole foot on a babylock companion 1550
1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
Oct 05, 2017 | Sewing Machines
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
Bar that hold the sewing foot is loose
If the comment already posted did not answer your question, here is another thing to check. If the screw that attaches the foot and ankle to the presser foot bar is tight, and the foot can still be moved, it is likely that the presser foot bar has become loose within the lifting mechanism. You could save yourself some trouble by taking your machine to a sewing machine repair shop, but if you would rather avoid that expense, do the following. Remove the needle bar and take up mechanism cover on the left side of the machine. This is held on by a single phillips head screw on the back side of the machine, which, with the back of the machine facing you, should be on the top right side of the machine. Once this cover is removed you will be able to see two vertical metal shafts, one is attached to your needle clamp and needle, and should be in the front. The other is the presser foot bar, and will be behind the needle bar. There should be a small allen screw about halfway up that shaft that tightens onto the bar. With the presser foot properly positioned on the needle plate, tighten this allen screw. Don't tighten the screw too tightly, as this can damage the presser bar, just make sure it's nice and snug. Make sure the presser foot raises and lowers properly, and re-attach the needle bar cover.
Hope this helps.
Mar 16, 2014 | Brother CS6000i Computerized Sewing...
I can't get the foot to lower and raise.
it sounds like it's out of time--here's how to fix it
to adjust the pressure on the presser bar and in turn the foot, locate the thumb
screw at the top of the machine
by rotating the thumb screw clockwise, you will increase the pressure, a counter
clockwise turn will decrease the pressure
the correct height of the pressure foot from the needle plate is 7mm.
to adjust this clearence loosen the screw & adjust the pressure bar through
the guide
secure the screw firmly when the correct adjustment is obtained
the distance between the presser bar lifting arm & the presser bar guide should
be 0.5mm ..( be sure the needle bar does not rotate left or right during the
adjustment process. the needle must be center of the presser foot & needle
plate hole,, if this is not centered re-adjust to the center of both needle foot
& needle plate hole.
Apr 07, 2012 | Sewing Machines
Remove sewing maqchine case
Plate on bottom: Remove screws. Keep screws in safe place and oil moving parts with good quality sewing machine oil. Zoom with spout for sewing machines & servers is what I use purchased online...lubricate gears with Singer lubricant (in tube). Tip machine back onto a towel to remove screws. Just one drop oil on moving parts & dot of lube gear only if not showing signs of grease already. Please remove bobbin and presser foot before cleaning/oiling. One drop oil then generously SMEAR oil on oscillating hook, open right front door & one drop top of needle bar. Clean out race shuttle for lint, fuzz balls, broken threads with soft sewing machine brush & clean your feed dogs gently with bristles too. Hope this helps. Do not clean machine near children or curious pets! I run my machine with pedal on table top so I don't accidentally step on it. Control with right hand to see moving parts. At your own risk, of course. Safe and effective but only if you are extremely careful. Replace all screws securely. Put in new needle all the way UP into needle bar groove, presser foot UP turning handwheel towards you, flat end of needle to back, Thread Front to Back of needle.. Keeping presser foot raised @ highest position ensures thread locates the tension slots properly. Jimmy
Apr 07, 2012 | Singer Sewing Machines
Bernina Artista 640 - While embroidering, the sewing needle hit a pin and broke. Now that I have replaced the needle, the alignment is off. The needle point comes down onto the embroidery presser foot.
This will probably need to be handled by a professional. With this particular Bernina, you might be able to adjust the needle position so that it is slightly off center and will not hit the presser foot. That would be a temporary fix, however. If you want to be able to thoroughly enjoy your sewing time, you will be happier if you take it to a certified Bernina repair site and let them adjust the needle position.
Nov 11, 2010 | Bernina Sewing Machines
Elna 220 Elnita - While sewing the needle arm moved all the way to the left only just clearing the presser foot. Any other setting (zig zag, button hole) the needle doesn't move at all. It's affected the...
It appears the machine has a variable needle position. Perhaps that was accidentally bumped thereby setting the needle at the left position.
Jan 04, 2018 | Sewing Machines
Needle position
Oct 22, 2008 | Brother CS-8072 Computerized Sewing...
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
May 05, 2008 | Husqvarna Designer I
Sewing Machines Logo
47 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
