Question about Coleman Mach III Air Conditioner
Do you know the exact charge weight. for tsr mach 3
The charging chart on mine says 18 oz of r-22
Posted on Jul 01, 2009
Big Boy TSR 250 scrambler manual
Hi, Anonymous and Wynand the vast majority of service, parts fiche, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee of $15 and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available and some were never printed in English. The Indian and Philippine markets are usually in E-book format only, for these rare occasions I shall look on eBay and find the cheapest one available. Most of the manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. If there is no $ sign after the manual link it is free to download.
To download your manual for viewing or printing please click on the blue links below. Good luck and have a wonderful day
Big Boy TSR 250 scrambler manual Google Search
big boy xtg 250 owners manual
Big Boy Replacement Parts Gumtree Classifieds South Africa
SAMotorcycles TSR250
https://en.wikipedia.org/wiki/Big_Boy
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 02, 2014 | Motorcycles
COLEMAN TSR FULL LOAD AMPS
Go to airxcel.com, you should get some options, to get either their literature or tech support and they should be able to help you.
Aug 07, 2012 | Coleman Mach 15 Air Conditioner
HOW OLD IS MY UNIT? IT'S A TSR MACH 3 WITH BLUE LETTERING THANKS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Feb 20, 2010 | Coleman Mach III Air Conditioner
Coleman TSR Mach air conditioning roof mount trips breaker
The simplest answere to start is it' looks like the compressor is the ssue." Either it has siezed"or in my oppinion needs a proper household power to activate it. If the voltage drop on these units is a little below a certain value, it will not start and will burn out. Thats why i suggest a household power be tried first. I feel your generator is a little undersized. You will only know once you have applied household power.
Sep 23, 2009 | Coleman Mach 15 Air Conditioner
Need solar panel monitor for coleman TSR
Wire it direct to batteries. It puts out very little amperage, so not to worry about overcharging the batteries. It's only basically a trickle charge.
Jul 10, 2009 | Coleman Mach 15 Air Conditioner
What are the 1st 3 blower settings for?
Those are for the run time of the circulating fan after the heat has been satisfied.
Jan 26, 2009 | Coleman Mach 15 Air Conditioner
Tsr mach3 conditioner
The smell is because of the stuff growing inthe water from the air conditioner. When you run the a/c it keeps the water condensed on the coil. When you turn the a/c off and run just the fan, it allows the water to warm up and start evaporating thus allowing the goodies in the water to become airborn. It would be adviseable to have the unit disassembled and cleaned by a professional due to the obvious danger of mixing water and cleaning chemicals with electrical equipment
Jun 25, 2008 | Coleman Mach 15 Air Conditioner
COLEMAN TSR MACH 3 COMPRESSOR
I would check the thermostat based on what you said it could be out of calibration
Jun 11, 2008 | Coleman Mach 15 Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Jun 11, 2008 | Heating & Cooling
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach III Air Conditioner Logo
157 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
