Question about Car Audio & Video
How do I eliminate a weird sound that my radio picks up ?
My radio is a kenwood exelon when I turn on the Bluetooth to listen to the music from phone and it works fine but when I turn on the headlights( with HID's) that's when I get the sound goin in to the radio
    Problem Solver:
  • 14 Answers
Make sure the radio is properly grounded to the body of the vehicle.
If that dont fix it you will need a noise suppressor llike that.
http://www.thatcable.com/product/10A-Noise-Suppressor-Filter-Eliminate-Car-Radio-Noise
Posted on May 09, 2014
5 Suggested Answers
  • 6 Answers
SOURCE: Music Won't Play
ok I had this happen before
Try unplugging the possitvive battery from your car let sit for 5min or open the doors and turn the key making sure that your car is completly dead. then put the possitive wire back on.
this will reset the deck and make sure you also have the setting s correct I thin it called I tunes is set to on in the menu opptions
Posted on Dec 29, 2007
Zackd9184
  • 56 Answers
SOURCE: installed a clarion radio it powers up but no music thru speakers
sounds like a short in your wiring to your speakers the best thing to do to check this is run a speaker wire directly to the speaker from the stereo check it that way and see if it works.If that don't work it's the wires on the stereo connection.The speaker wires on most aftermarket stereos are mostly colored 2 of each green,purple,white & grey.
Posted on Nov 09, 2008
TOLhamRadio
  • 509 Answers
SOURCE: 2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Posted on Aug 02, 2009
SOURCE: bluetooth on sony radio will not pick up phone signal
why wont my bluetooth signal stay on for me to connect to my phone
Posted on Oct 14, 2009
I'm having a problem when i listen to music threw Bluetooth on my car stereo, when i play music using Bluetooth from my phone my subwoofers don't turn on, but when i listen to the radio my subwoofers work
Generally, subwoofers require separate circuitry. Your car radio has that circuitry. Bluetooth is set up for stereo only and your phone will only supply stereo output
Nov 07, 2014 | Cell Phones
It's like I listen to music and I can't hear the words. The music sounds bubbly . It weird. I have cloudphones in blue with a mic and remote. Please help
Also be careful of jewelry (heavy watches/rings) in between your Bluetooth headphones and phone. They can often interfere and will result in the condition described. As well try ensuring the headphones are fully charged as lack of power can also result in conditions described
Aug 25, 2013 | Audio Players & Recorders
When listening to music via Bluetooth On my kenwood DNX8190hd, my subs don't work. That being said, the subs do work in any other mode. Radio iPod etc. What is the solution
go to Bluetooth settings and turn on the all speakers setting and all will be good... also use accessory turn on from the radio for amp turn on. unless kenwood changed something the remote turn on is weak and doesn't always work
Jul 25, 2012 | Car Audio & Video
I want to connect my nokia BH-104 headset tp my blackberry bold 9700 phone. Please guide
  • 1
    Turn on Bluetooth headset and Blackberry hand-held.2
  • Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
  • Mar 20, 2011 | Nokia BH-104 Bluetooth Headset
    Clarion cx609 after my lg rumor 2 pairs with radio and I am listening to another source 30 sec later the Bluetooth audio turns on for my lg rumor . I never tried to pair it for bluetooth audio.
    I had this same problem; here's what I think is happening. You have several bluetooth "profiles" on your phone; one of which allows for music streaming (A2DP) through BT. If this profile is enabled on your phone, then the radio "senses" that you've got a new source hooked up, that being your phone's music player. It's similar to if you're listening to the radio on the CX609 and then plug in your iPod--the radio senses a new source and swaps to it. If you disable the A2DP profile (assuming you don't use your phone for streaming music through your CX-609), and only leave the headset and/or handsfree profiles active, the radio WILL NOT switch to bluetooth mode. I did this on my Blackberry Tour and I now can enjoy my radio much more than when I had to swap back to the radio 30 seconds after I turned the key. Hope this helps!!!
    Nov 15, 2010 | Clarion CX609 Car CD/ MP3 Player
    Sony erricson k800 cant recieve files via bluetooth although i can send via bluetooth.
    Did you turn the bluetooth on and put the phone in discovery mode before attempting to receive something via bluetooth?
    May 01, 2008 | Cell Phones
    Google Navigator will not pick up my bluetooth GPS readings
    Just using the 'Settting manully' and set the port and bardrate
    Mar 22, 2008 | Navigator Amcor Amigo 4300B GPS Receiver
    Car Audio & Video Logo
    53 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
