Question about Sony Handycam DCR-TRV265E Digital Camcorder
Code: 31:23....please reinsert tape. everytime i switch it on.
Everytime i switch on my sony i get a message saying please reinsert tape and a code number comes up as well.the code is c:31:23. i have tryed new tapes and even taking the batteriey of for a few seconds and left the back open for 24hrs and the retryed and it still comes up with the message and the code. please help me. thank you kalvin.
  • 72 Answers
Dear
u need to rate me for that ..ok dude....
actually this error is related to s reel i.e, the supply reel of the camcorder and some time when we insert a new tape in camcorder it start giving the error because the amount of tension is more in new tapes as compared to the old ones (used one) . . try to use the old tape u would nt have any problem .
but with new tape u will have these kinds of problem some times , to solve this problem for new tape u need to take the camcorder to near by service center of sony .nd they will align the tape path of your camcorder .
Posted on Jun 30, 2009
  • 4 Answers
Dear
First try with good working cassete
This is common problem you must change the mechanism with out drum <use the old drum assy > for final solution then must make all the mechanical and electrical adjustments . experts tech and tool needed . unfortunely this mechanism is better ex
change for repair not good idea to repair the same one.
Posted on Nov 03, 2014
    Scholar:
  • 70 Answers
These error code means that there is a problem with the take up reel. The tape up reel is responsible for "taking up the tape slack" as the tape is running. Try resetting the camcorder. This is done by removing the battery or ac power, wait 10 seconds, reapply the battery or ac power and try again. however..seems this usually happens when the tape has run out of time whilst recording, you have changed the tape....and your re-inserting the tape again for transfer trying to rewind it correct?.....either way, pull the battery off, have the power chord ready plugged in as the only power source, close the tape door...and just as it loads pull the power chord out as you just hear it try to wind up....then wait a few seconds, (your on switch is in VTR or VCR mode......quickly put the power chord back into the camera and repeatedly overide the commands by hitting the << REW button or FFW>> the camera should have bypassed the error alert and start winding the tape....just let it wind the tape for about 20 seconds...hit stop....pless PLAY > you should have normal function again. and go to where you wanted the tape to be.
Posted on Nov 02, 2014
I just put a new black ink cartridge into my printer and now it says error with alignment I've reinserted the cartridge several time and it says the same thing everytime. What do I need to do? and...
Make sure you are inserting the correct version of black cartridge for your model. Try to remove both cartridges from the printer. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert your cartridges. You can also try to insert a different known working black cartridge to determine if the other is faulty.
Jun 26, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have a sony dig 8 trv340 and am receiving an error code of c31:42 what does this mean?
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Thanks.
KenSolutions
FixYa
Oct 23, 2010 | Sony Video Cameras
I get an error message everytime I try to record
There is a switch on the VCR that says "tape/other". Change the switch from "other" to "tape" and you should no longer receive this message.
Mar 22, 2009 | ION Audio VCR 2 PC USB VHS Video to...
Joanna
This is mechanical problem of Take Up Reel section and system control chip doesn't get reel pulse and you see reinsert tape message (error message)
Repair of this mechanism is delicate work and prior experience does matter here. If you have camera repair knowledge and experience, you should check take-up reel section in camera mechanism.
Good Luck.
Dec 12, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony bvw 35
robairto- Do you recall what the error code is?
Jun 03, 2008 | Sony PVW-2650 VCR
Sony handycam video hi8
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Nov 26, 2007 | Sony Handycam CCD-TRV108 Camcorder
SONY DCR-HC39E
I had the same problem. I would suggest going to the service with it. The "head" needs changing.
Oct 13, 2007 | Sony DCR-HC39E Mini DV Digital Camcorder
It keeps making a beeping noise and wont let me record or do anything!
Try taking off the battery and reinserting it to see if it resets mech,If this doesnt work you wil have to bring to service.Dont go at it yourself as you could cause serious problems,
May 23, 2007 | Sony Handycam CCD-TRV68 Camcorder
Sony Handycam DCR-TRV265E Digital Camcorder Logo
216 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
