Question about Vacuums
Eureka AS1001 troubleshooting
The vacuum started right up and then went off, read it could have been from over heating. Now It will not start at all, If the motor is gone is it worth it for me to replace myself?
  • 328 Answers
If the motor is overheating, it wouldn't start up all the time and then switch off - sounds like something is blocking the system- check that the filters are completely clean and check the suction channels for any clogs as well as the main hose and the tools, if they are part of the system for suction air flow.
Posted on May 09, 2014
  • 430 Answers
SOURCE: Eureka canister vacuum cleaner Model 6865
The 6865 has a high rpm AMTEK Lamb motor, Brushes will seldom solve the problem at this stage.
Once the sparking and burning starts the conectiion between the brush and commutator is arcing and burning. If the sparks are blue, save your time.
A good service tech will run in brushes with a seating stone and a low voltage setup to allow new brushes to seat, but this is generally best accomplished on heavy duty , lower rpm motors.
IF YOUR ARMATURE IS SCRATCHY LOOKING OR WORN LIKE AN APPLE CORE,OR THE SEGMENTS ARE NOT PARALLEL IN THE SPACING YOU WILL NEED A NEW MOTOR.
Posted on Oct 16, 2009
chrispurs1
  • 372 Answers
SOURCE: Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Posted on Sep 09, 2007
reddevil6
  • 1673 Answers
That the bottom plate off, check for a clog in the inlet. If clear, then you probably have a clog in the handle tube. You will have to take the handle loose to clean it out. It may also need a new belt if you haven't changed it for a while, they stretch.
Posted on Feb 05, 2008
reddevil6
  • 1673 Answers
SOURCE: Eureka Wide Track Superlite vacuum roller brush motor
Don't know if you can find something that will work, Eureka doesn't make these motors available thru them. Try some local shops or a place that sells small motors.
Posted on Jun 17, 2008
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12164&thid=669867
Posted by mjtnm on Jun 14, 2008
The brush motor went out. Is it possible to buy one and splice it to the existing wires? Where can I buy one? The vacuum is model #409 the number on the dead motor is: DA-20L-2001, 17.5V DC AOM 4293S
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 421A EZ Kleen Bagless Stick Vacuum. Yes, you can replace the power nozzle motor in the head of the Eureka 421A EZ Kleen Bagless Stick Vacuum by either contacting the local vacuum cleaner dealer in your area or to contact the Eureka factory and ask for cust serv or tech support or parts and they will direct you to the correct dept to order the P/N motor so that you can install it and get on with your cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
Brush will not spin
First thing to check is the belt to make sure it is not slipping and make sure the brush roll isn't restricted.
Apr 07, 2014 | Eureka EUR AS1001 Airspeed Gold Bagless...
Eureka powerline umc-18 vacuum quit working
The Motor has locked up due to over heating. Once that happens the only way to go is either replace the motor drive or get a new cleaner. Do not try and keep energizing the Vacuum as you could blow circuit-breakers or start an electrical fire.
Dec 18, 2013 | Eureka 1810 Central System Vacuum
Eureka vacuum wont start model AS1101. not clogged
Possible bad cord, or bad plug at the end of the cord. Take it to a vacuum repair shop
Oct 12, 2013 | Eureka Vacuums
Will not start
Check for a reset button on the side of the machine near the brush roller area.You may need a new power switch that often fail after the machines over heat or refer to this DIY vacuum cleaner guide.take it into a eureka vacuum service center
Jun 05, 2012 | Eureka As1001a Vacuum
My vacuum worked fine yesterday and now doesn't start
To my knowledge, the on/off switch is the only area to turn your vacuum on or off. There might be a problem with your cord, or with the switch itself. I suggest checking for clogs and anything that may cause a problem.
I also suggest taking it to a local vacuum shop to have it looked and as you may need some new parts (cord/switch)
Apr 13, 2010 | Eureka Whirlwind 4388 Bagless Upright...
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka power failure
The windings have a temperature sensor that "usually" resets when it detects an over heating problem. The other alternative is a light bulb in series with the motor that has popped, this will stop the motor from running.
I'd bet on the thermostat in series with the windings first though, can be replaced if you can get the cleaner apart.
Dec 31, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
Vacuums Logo
81 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
