Question about Dataproducts FP 2000A Matrix Printer
Gosting problem It has a "Gosting" print problem where ink smudges show around the print!
    Scholar:
  • 122 Answers
Take off the ribbon and wipe and clean the area around the printhead, you probably have buildup there. Check the ribbon and make sure that it is in good shape and not fraying.
If you cannot get to the face of the printhead, you can remove it to make cleaning easier
Posted on Jun 22, 2009
When I print a glossy photo print, right at the end the printer makes a noise as if its labouring and there are excess ink smudges on the corners of the print. It only happens when printing glossy paper.
i think the problem is with your print head. i have the same problem before. when i put out the print head to check. there's a lot of excess ink. this may be the reason for the ink smudges on the corners of your print. and when you set your printer to photo printing. it is programmed to put larger amount of ink than normal printing. the best way is to have your printer checked by your service center or change your printhead to a new one. goodluck!
Apr 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I'm trying to print wedding invitations on my Canon MP460. I'm using a cardstock thickness of paper and have set the ink levels for "Other Photo Paper" on my Mac. The paper has been going through...
Sounds like the ink isn't having time to dry and is rubbing along paper.
Paper may be too thick. If it prints OK on normal paper (test first) but not on thick card, then it doesn't support thick paper settings.
Jan 31, 2011 | Canon PIXMA MP460 All-In-One InkJet...
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Ink smudging off paper
It means that the fuser is not hot enough to bond the toner to the paper. You should open the rear door and see if a paper has wrapped around the fuser roller, as when the temp is actually too cool it will shut down the printer. Photo paper is also too thick to be used in this printer and you should only be using standard bond paper.
Feb 22, 2010 | Minolta magicolor 2400W Laser Printer
Blue color appears pinkinsh/now stripes and smudging
Are you using third party ink? make sure your ink is xerox OEM. This will clogg up the inkjets and ruin the print head for ever, If you have always used the third party ink then you might want to get a new print head. . If you have used xerox ink then It sounds like the magenta reservoir has spilled over the cyan. This is caused by moving the printer and not waiting for the cool down procedure. Also you might want to change the print head wiper. If the print head wiper is over used it won't clean the print head properly and what that causes is for ink to build up and causes smudge. also make sure the drum maintance kit is still in good shape. (its the yellow roller on the right side of the printer. Well hopefully this helps .
Nov 20, 2009 | Xerox Phaser 8400 Laser Printer
Ink comes out heavy in spots on print outs as if you had a jam and then the ink smudges - ink does not smudge just heavy on certain spots
Sounds like you need to replace either the fuser or the rollers the rollers could have ink build on them and it would smudge the ink.
Oct 21, 2009 | HP LaserJet 6p Printer
Brother MFC 7820N Smudging Concern
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Print out is dirty, there are smudges of inks at the page center
What colour are the smudges, if they are one colour you can try changing that colour toner cartridges. Failing this then it sounds as if you may need a new drum
Dec 09, 2008 | HP LaserJet 2550L Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Dataproducts FP 2000A Matrix Printer Logo
60 people viewed this question
Top Dataproducts Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Dataproducts Office Equipment and Supply Expert? Answer questions, earn points and help others
