Question about Garden
How do I get the string back into my robi tiller
  • 957 Answers
You have to take the spinner out and rewrap the rope. this is not easy and if you are not good working with your hands I would not try it. there is a spring there that has to be reset. could be that the recoil spring could be broke.
Posted on May 09, 2014
What weight of oil is used in Ariens st622 string trimmer with a tecumseh 6hp motor
Since this is used in the summer any good grade is SAE30 oil will protect the engine..no need for muti viscosity oils..good luck.
Oct 02, 2014 | Ariens Wheeled String Trimmer - 946152
How do i repair pull string on my yard machine 135202 tiller
remove starter
get new rope
wind spring DONT LET GO UNTIL DONE
feed in new rope , tie knot in rope, replace handle ,tie knot in that end. NOW YOU CAN LET ROPE RETURN IN SLOWLY
May 10, 2014 | Mtd Products Yard Machines 158CC Tiller
How do you fit the pto to a merry tiller for a flexible drive shaft saw attachment
flex shaft nits are not made to handle anything other than a string trimmer
May 03, 2012 | Garden
I was using the lawn machine 31cc tiller today, the black handle with the string flew off (about 20 ft), I was able to re-thread the string back through the hole and handle but now I have no recoil. ...
You need to tension the spring also. On youtube donyboy73 has good video on how to do this and he shows you how to adjust string tension with the string still attached. I think it is in a video about Tecumseh engine/snowblower recoil starters. If you can not find it, let me know and I will write it out for you.
Sep 09, 2011 | Yard Machines Garden
I need to find someone who can tell me on how to replace a primer bulb on a Robi Till/caltavitor, the one that on it is dry rotted. Can someone please help me? Thank you
If you take a small screwdriver and go between the primer bulb and where it sits you will see a metal ring that holds it in, use the screwdriver to take it out. It sometimes takes a bit ou patience. Before you do any of that look around the outside that housing and look for small tabs that you push on to remove the primer bulb. New ones just snap back in. I think if you take a closer look you will see what I mean. Hope this helps. Best regards and good luck.
Jan 08, 2011 | Ryobi Cultivator
Need info. on old montgomery ward powerkraft tiller. model: # giL1580 se rial:#0323f1 437. tiller needs new 2 new belts for starters. i dont know how or where to get the correct ones. has briggs and...
if it has old belts pull them off and go to any parts store for them to be matched up. if not get you a piece of good strong string and run the string around where the belt goes and measure belt lenth that way.
Oct 21, 2009 | Garden
I have a robi 31cc don't know how to put on new string has double head i can't put the string on
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 15, 2009 | Ryobi Garden
Cord is frozen and tiller won't start
take pull rope cover off and oil the clutch that screws on the crank shaft
Apr 24, 2009 | Mantis Tiller
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
