Question about aFe 2001 Ford Ranger - 2.3L 4-cyl. engine - Air Filters
How do you fix a code P 1506 ?
Idle runs high when not pushing on the pedal
  • 20 Answers
Hi Joel,
Here's what you were looking for. Idle Air control valve
http://upkeep.us/OBDII/OBD2/Ford/piart.php?art=5282
2.3L 2002 Ranger part page for reference & repair video. Same engine, etc...I do not work for Rockauto it's just a part/price reference.
http://www.rockauto.com/catalog/x,carcode,1372676,parttype,6072
Repair video
https://www.youtube.com/watch?v=iQr6E9Z7sg4
FYI, video for IMRC shows issues which are sometimes related.
https://www.youtube.com/watch?v=qLqpQeIJXek
PEACE
Posted on Jun 22, 2014
Will not operate, no reaction when power button pressed. All panels properly locked.
first off does the light come on at all? when the switch is moved to the High Medium or low setting do you see a red light or a green light on the right side of the unit? if there is no light at all, then there is either no power and you have a bad cord or a bad outlet. The only other thing could be the switch that needs to be tripped in order to let the unit run, that switch is closed by the front cover locking in place. that switch could be bad or your cover may have the tip of the pin that pushes the switch closed broken off or deformed and not pushing down enough to close the switch. try pushing a screwdriver down on the switch and see if it comes on. There's nothing that can shock you if you push on that switch, the power wires are concealed inside a plastic covered area that the switch slides into. If you close the switch and it doesn't come on the check the power cord or the wall socket for power. See if the cord has any unusual looking spots or lumps, stretching, cuts or anything that looks suspicious.
Apr 06, 2015 | Oreck XL Professional Air Purifier
Would a bad intake gasket cause a check engine light or for the insufficeint flow to EGR code come up?
Yes it can be. Here is a simple way to check for a intake leak. Get a can of crab cleaner. Start the motor, let the motor idle if it will. Spray the crab cleaner around the intake where it bolts.to the cyl heads. If the intake is leaking you will hear the motor idle change. You can check vac lines the same way. Hope this helps you find the problem.
Jun 12, 2014 | aFe 2001 Chevy Impala - 3.4L V6 - Air...
Why is my Toyota LC not accelrating beyond RPM 3.
try to reconnect the check engine sign (make the OBD system operative), it looks like the fuel injetion calculator is not working properly
May 11, 2014 | aFe 2005 Toyota Land Cruiser - 4.7L V8 -...
Abs light on on the dash and a motor under van stays on when key is off
the motor you are hearing could be the abs pump. abs light will not come up on a code reader for engine as its classed as body part. if it is this pump then the system is faulty and the pump running can mean that it has a broken fin inside you cannot fix this part and another abs pump will be need to fix this.
Mar 11, 2014 | EBC Brakes 2001 GMC Safari - AWD, without...
My car is jerking when I push the gas pedal
Check motor mounts and transmission mount
Also check the air tube (TOP AND BOTTOM) for hairline crack.
A worn motor mount can cause excessive vibration and damage the air inlet tube.
Jan 15, 2014 | Spectre 2004 Audi A6 - 3.0L V6 - Air...
I just purchased a used Alpine Air XL-15 from ebay that was listed "AS IS" because it didn't have the "3" ozone plates required for it to run. I have properly placed the new plates that I bought and the...
Also check the Fuse. Its on the back of the unit. Press in and turn to remove it. You may be able to just do a visual check and see if the fuse it is still good. however you may want to test it for continuity with a Multi-meter.
Mar 06, 2010 | Alpine Air XL-15 Air Purifier
Light doesn't come on, does not purify the air.fan runs
If the little orange neon light no longer comes on, it is a problem with the high voltage board and transformer. The board sits on top between the plates and the fan.
In my instance, the board had become corroded and shorted the terminals of the voltage regulator located on the board. Also, the ground strap around the ferrite core of the high voltage transformer had become corroded an needed replacement. Also, check the circuit paths from the nearest components to the Voltage Regulator pads. Mine blew one of the circuit traces.
All in all, I replaced the Voltage Regulator, Mouser P/N: 595-UA78L12ACLPE3, Transistor P/N: 512-2N4403BU, Timer IC P/N: 595-NE555P.
The voltage regulator feeds the latter two, as well as the high voltage transformer, I replaced those components as a precautionary measure.
The terminals do get corroded, so check those as well. There are no terminals on the high voltage board other than on top of the proprietary potted black box that feeds the target and neon light. Be careful with the terminal on that box because it breaks easy once corroded. As mine did.
Those components fixed my problem with the high voltage board and no neon light.
Hope this helps, let me know if you have any other questions.
Sep 19, 2009 | Ecoquest Flair Air Purifier
Have a silent air purifier quadra model # s1637
If, when you push the on button it sizzles for a sec and then shuts off (clean light goes on), I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Feb 12, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Green light is on but will not operate
Hi Bran44dy,
Because this purifier is essentially a filter in a box with a fan pulling/pushing air through, I can only guess that "will not operate" means that the fan isn't moving the air.
1) Is there a fuse that you can check to see if it's blown?
2) Have you tried resetting the Filter Life Indicator button?
3) Is it still within warranty?
The instructions for this unit recommend operating it at MEDIUM level on a long-term basis - - evidently, it isn't designed for continuous high-speed operation. If it was running with a blanket over it, it's conceivable that the fan motor overheated and quit. Unless you are into repairing electric motors (probably not, the best you can do would be to replace it). Try contacting Jarden Consumer Solutions Customer Service at 1-800-546-5637 - - if they won't sell you a motor, you might be able to find a generic one on the Internet, but with a MSRP (Manufacturers Suggested Retail Price) of ~$90 (when new), it's going to be easy to spend more time & money fixing this than it's worth. There are lots more durable purifiers out there, though you'll likely have to pay for it.
Dec 26, 2008 | Holmes Products HAP650 Air Purifier
Not returning to 100%
Reset filter reminder:
Unplug power code.
Push and hold sleep button.
Plug power code while pushing sleep button.
LCD shows "P" than release the button.
Push sleep button and you can see 99% filter reminder.
Jul 09, 2008 | Bionaire BAP1300 Air Purifier
aFe 2001 Ford Ranger - 2.3L 4-cyl. engine - Air Filters Logo
115 people viewed this question
Top aFe Air Purifiers Experts
Dan Webster
Dan Webster
Pcm2048
Are you an aFe Air Purifier Expert? Answer questions, earn points and help others
