Question about Earthwise Ps40008 8 Inch Corded Pole Saw
The pole was boxed in 2 pieces which insert together and snaps in place, except i snapped it in backward, now the control end is upside down. how do i unsnap the pieces?
    New Friend:
  • 132 Answers
There should be a retainer clip or ball (like a ball bearing) somewhere along the pole that holds them together. Might be hard to locate but should be somewhere within three inches of the end. If you can't find it, go back to the store and look at a new one that is still apart and see what holds them together.
Posted on May 29, 2014
How to remove agitator
Remove the dispenser and then the bolt below. Then grab the agitator and yank it out. Separate the 2 pieces by placing the agitator on the floor. Hold down the base with your feet and yank the top portion off there. then you can replace them worn out dogs.
I like to hold the bolt and slip the cam upside down into the upper portion and then line it up with the base and snap the 2 together.
Video how to
Nov 09, 2011 | Estate TAWS800JQ Top Load Washer
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
I took apart my eureka quick up vacuum and am not sure how to re assemble
I just did the same thing and had to reassemble also. I recommend turning it upside down. First make sure the belt is wrapped around the motor threads as well as the brush threads, then rest the brush more or less where it goes in the front of the vacuum. The white plastic pieces each have a small hole - you need to insert one end of the brush into each while plastic piece. When you lie the plastic piece flat you should see that the other end fits together with the top of the vacuum. The trickiest part is getting the tiny little wheels into place. Just worry about the 2 in front first. Set them carefully into place in the square holes in the front corners of the machine. Use your finger or a screwdriver to fit the mini axles properly into the grooves. Carefully push the bottom of the vacuum into place until it seems to snap in place (be careful that the wires are tucked in well) and screw in the 4 main screws. Final step is to reattach the smaller black cover to the bottom (back) side - be sure to get that wheel in place before fitting the cover on and then tighten up the final 2 screws.
Mar 25, 2011 | Eureka& Cordless Quick Up Vacuum
How to disassemble Braun pulsonic razor,.. yes there's a screw in the 12volt inlet but there must be others else where, I assume under the rubber cover,.. but how does that come off so it may be...
To disassemble a Braun 9595 (and others like it):
Remove the rubber back and side piece by prying with a small screwdriver on one side near where the three arc design meets the silver body (photo 1). After releasing one side snap (photo 2), release the opposite side snap or use your fingers to pry around the rubber piece until both snaps are disengaged and the piece can be removed (photo 3).
This reveals the back of the shaver, which is held in place with four Torx screws. Fortunately, the screw heads are slotted so that either a torx wrench or a slotted screwdriver may be used for removal.
After the screws are removed, the shaver back plate may be lifted out (photo 4), exposing the battery and control board assembly, and the shaver/motor assembly (photo 5).
The battery is not soldered in place and may be removed by prying on one end to lift its positive or negative pin away from its contact. Then remove the battery (note that the negative side points to the shaver head. Also, the positive and negative pins are sized differently to prevent accidental reversal.
Reassembly has one essential step that must be followed or the razor will not function properly. Photo 6 shows the correct engagement of the shaver's back plate plastic pins with the shaver head's capture slots (shown "upside down"). Photo 7 shows the potential misalignment after the shaver head is inserted into the shaver body for reassembly. To overcome this when installing the shaver's back plate, ensure that the back plate's pins are first inserted into the capture slots (photo 8). Although the back plate may not appear to be positioned properly at first, it may be pushed downward which will "pull" the screw holes into alignment for inserting the screws.
Before inserting the screws, test the power ON button to ensure that all contacts have properly been made. If the shaver does not operate, check to see if any of the power tabs have been bent away from its associated contact point.justwomore_8.jpgjustwomore_7.jpgjustwomore_6.jpgjustwomore_5.jpgjustwomore_4.jpgjustwomore_3.jpgjustwomore_2.jpgjustwomore_1.jpg
Feb 07, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
I have a rio grande train set and I can not figure out to put the tracks together?
HOLD TWO PIECES OF TRACK TOGETHER SNAP ONE SIDE TOGETHER THEN SNAP OTHER SIDE.
May 28, 2010 | Scientific Toys North Pole Express Xmas...
Hello. I have a disney princess bed tent that my daughter recieved for christmas. We went to go and set it up and the instructions are missing. Is it possible to get a copy faxed/emailed to me?
I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
May 19, 2010 | Toys
Trying to connect agitator without dogs getting out of place
I thought the two parts would snap/connect together. They don't. Put the agitator on upside down over the "dogs" and their connector. Holding that together put the top agitator over the bottom. Carefully put over the metal connector inside the washer and connect the bult. The bult is what holds the pieces together.
To take apart initially I had to use a socket set with a long extension and a pipe over the racket handle to get enough torque to loosen the bult
Dec 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kodak EasyShare Z612 Digital Eye piece
you have to take off the back plastic part of the camera carefully. I snapped it off carefully. Then you take off 2 black screws at the eye piece and insert the rubber. screw back together. snap plastic back on and screw in all the screws. have fun!
Jan 09, 2008 | Kodak EasyShare Z612 Digital Camera
Earthwise Ps40008 8 Inch Corded Pole Saw Logo
82 people viewed this question
Top Earthwise Saws Experts
Tom Chichester
ray gallant
Are you an Earthwise Saw Expert? Answer questions, earn points and help others
