Question about Sewing Machines
How do you repair a 311 code on an embroidery machine
  • carol janet larson
    carol janet larson May 09, 2014
    it is a TMFX 2-c Tajima 6 head embroidery machine
  • Sewing Machines Master
  • 662 Answers
Need to know the brand and model of sewing machine. They are all different.
Posted on May 09, 2014
Testimonial: "Hi Jimmie, Thanks for responding but a card inside the motor had to be rebuilt and was not a home project. This was a 6 head tajima embroidery machine. Thanks!"
My Bernini 830 would not recognize the embroidery attachment. I re-attached many times, but it doesn't work.
I assume you mean a Bernina 830. If you have removed the slide-on table, I have two possible solutions. I've seen this with a couple of Viking embroidery attachment units. (I am also assuming it's not a hoop issue.)
You could have corrosion on the pins that send the signals between the embroidery attachment and the sewing machine. Remove the embroidery attachment and turn off the sewing machine. Unplug the sewing machine. Spray the pins with an electronic contact cleaner; one example is here: http://www.homedepot.com/p/CRC-QD-11-oz-Contact-Cleaner-02130-6/202262505 . Push the embroidery attachment into the sewing machine by lifting up the far side and then sliding it into the port. Remove the embroidery attachment. Repeat this a few times. (The friction of the insertion and removal will remove any dirt or corrosion.) Plug in the sewing machine and turn it on. Try connecting the embroidery attachment. If it works, remember to clean the contacts the next time the embroidery attachment isn't recognized.
Once I helped someone with two sewing/embroidery machines with an unrecognized embroidery attachment. In that case, the person swapped which embroidery unit went with which machine. The contacts were not the same and didn't mate. Once the correct machine and embroidery unit were paired, the embroidery unit was recognized instantly.
I hope this helps. If it doesn't, you may need to talk to your Bernina repair technician at your local shop.
Aug 19, 2017 | Sewing Machines
I have Tajima embroidery machine TFMX1508 Igot error code 6D2 what's wrong is it who knows
This should be in your Troubleshooting guide in the manual.
Here are some codes related to trouble codes on a Tajima machine, may need the correct error codes for your make Model machine.
http://www.theembroiderywarehouse.com/errorlist.pdf
Cheers and good luck!
Embroidery Services
San Diego, CA
Aug 07, 2017 | Sewing Machines
After cleaning the bobbin sensor, error message keeps coming on. What else should I do?
You should probably take it to a Bernina repair person.
https://www.youtube.com/watch?v=RHYwvv8lJ74
http://sewsabina.com/blog/?p=84
http://freemo.com/bernina-artista-730e/
Jun 23, 2016 | Bernina Artista 640E Sewing, Quilting and...
How do i repair X-Axis home position error for pr 600II
If the machine's embroidery arms have been moved under force when the machine's power is on, you may need to have the machine tune up and reset to true center. I would suggest taking it to a authorized repair shop for a good cleaning and service. In most cases for what you paid for the machine, there is included service that can come with the purchase of the machine, or in the least, a discount on mechanical services and repairs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Mar 02, 2015 | Sewing Machines
On an Elna 9006 sewing machine I have an error that reads ( stepping motor error) what does that mean.
Time to get this machine a repair shop. Motors in embroidery unit may be bad or headed that way...
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 11, 2014 | Sewing Machines
Janome
Sounds like your embroidery unit may have a bad motor or broken drive belt. Get that unit into a repair shop.
Cheers,
Kelly
San Diego, CA
Jul 30, 2014 | Janome Memorycraft 9700 Computerized...
Embroidery unit on Brother pc8500d will not work
Hi Sharon,
That was my first "Convertible machine" I had the Baby Lock version. Exactly the same in every way, except for the name badge.
Make sure you have the "data door" open (revealed after the tool tray free arm section is removed.) and the "Feed Dog" Switch is "down for embroidery". If any of the connection tabs/pins on the "embroidery attachment" are missing or bent/broken off. the embroidery arm will not work properly.
With this old of a machine, look on EBay for external parts and things you need instead of seeking repair. Timing adjustments, and other machine maintenance can be done by most repair shops with a technician that repairs convertible embroidery/sew machines.
Put your machine name and model number in a search on youtube.com you will find a wealth of information there for your machine.
Cheers,
Kelly
San Diego, CA
Embroidery Services
May 18, 2014 | Brother PC8500D
On 955E embroidery unit, the large black gear snapped
Welcome to FixYa. Hi - Viking has online tutorials for several of the 955E features, including embroidery.
Here is a link to the 955E tutorials. If the link isn't active, paste it into your brower window.
http://www.husqvarnaviking.com/us/6616_393.htm
As mentioned in the next paragraph, you can order a manual from your Viking dealer if you don't have yours. The Viking manuals aren't very expensive, and it is well worth having. You'll find detailed instructions for inserting and calibrating the embroidery arm, which happens everytime you insert the emb arm. See the Hints and Tips paragraph below.
If your machine is broken, the 955E Parts manual lists each part number in the machine, and the 955E Service Manual should provide instructions for repair. But because the 955E is not discontinued (as far as I know), the dealer might not be willing to sell you those manuals or order the parts you need. eBay often has Parts and Service manuals for sale for current model Viking machines, or you might be able to find them for sale on other web sites. Keep in mind that if your machine is still under warrantly, you risk voiding the warranty if you attempt to remove the covers and perform a "non-consumer" repair.
Some general hints and tips for inserting and removeing your embroiodery arm and navigating the Viking web site:
  • Always turn your machine off when you attach or remove your embroidery arm or when you insert or remove an embroidery design card.
  • When you insert your embroidery arm, insert an embroidery design card. When you turn your machine back on, you should see a message on the info screen that says something like "embroidery arm will move". Press OK, and the embroidery arm will calibrate.
  • After the embroidery arm has calibrated, place your hoop on the embroidery arm.
  • Look at each end of your embroidery arm - you will find a connector that must slip into a corresponding connector on the embroidery machine. This connector slides into a corresponding connector on the machine. The connector on the machine has a cover that slides open and closed. If it is closed, it you might not spot it right away. You must open this slot when you attach the embroidery arm - slide the embroidery arm straight back (not at an angle), so the embroidery arm connects to the machine securely. Although you might need to nudge the embroidery arm in place, do not force it!
If you or other viewers have a minute to rate my response (good or bad), your rating will help me to determine whether I unserstand your question and provided useful information. These ratings help me provide better service.
If you have additional questions or more information to add about your situation, please feel free to comment.
Cheers,' Ginny
Feb 10, 2009 | Husqvarna Designer I
Sewing Machines Logo
57 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
