Question about Mitsubishi WD-65638 65" DLP HDTV
Its fine for a little bit and it dose this flicker thing in the top left of the screen i dont know whats going on
  • Daniel martin
    Daniel martin May 10, 2014
    Could it be when the tv is hot and the fan makeing something move this tv has been move to place to place
VIZIO 42in LCD HDTV - Dark colors and flickering
It sounds that the back-light CCFL lamp is faulty. It is time to replace it. When replacing, do it to all CCFLs, because, the life time to these lams are expiring now, as the set is nearly 4 years old. Check this link http://electronicshelponline.blogspot.com/ to get more details about how to replace the CCFLs. Pull up older posts there. Some among it have details.
May 29, 2013 | Vizio 42 in. LCD TV
I have a Sanyo 42" LCD tv model DP42649. The
The problem i'm having is, when you turn the tv on it has a split screen with the left side shaken off a little bit. if you give it a tap on the left side it will flicker and the whole screen will come on.
Dec 29, 2010 | Sanyo 42 in. LCD TV
Car won't start and dash light flickers
Sounds like bad connection at battery. Remove the battery connections, clean the battery posts with a wire brush, and reconnect battery. Make sure connections are tight.
Jun 03, 2009 | 1999 Acura TL
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Flickering screen and no display
thats the complaint of LCD inverter circuit...if u dont know to open it,then dont do any thing better thing is go to the nearest service center of toshiba and try to repair it if thats failed. u have to replace with a new inverter circuit.dont try to repair urself...thats all.
Dec 13, 2007 | Toshiba Satellite P25-S507 Notebook
Acer 5610
If you get the windows splash screen and it goes black that would be an indicator that your backlight is bad. Try to hookup an external Monitor to determine this. Otherwise if you get no image at all even when you connect an external monitor. You need a new HD and must relaoad your OS, and all programs! Let me know!
Nov 26, 2007 | Acer Aspire 5610-4648 Notebook
Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
Mar 18, 2007 | Toshiba 15VL33B 15 in. LCD Television
Screen flickers
The problem is that it is on the verge of going out my mother had a monitor go out and it did the same thing. Also if you have any high frequeny things around your monitor thatr also migh be the thing. Try a magnet or demagnitze the screen if you have one on it.
Dec 04, 2006 | ViewSonic G810 21" CRT Monitor
Mitsubishi WD-65638 65" DLP HDTV Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
