The problem with xqb90-701 machine comes up with e2 code will noy rinse ,empty or spin
Fills up and washes but won't do rinse cycle or spin cycle e2 or e3 code appears
  • 957 Answers
I don't know what the codes are for this washer but it sounds like it has to do with the pump not coming on and pumping out the water. most of these front loaders have a clean out for the pump filter you should find it between the pump and where the drain hooks up to the tub. many times they get clogged with stuff. I worked on a whirlpool the other day that had a large sock stuck in it.
Posted on May 09, 2014
SOURCE: fills washes rinses but wont spin properly or empty out
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Posted on Oct 19, 2007
SOURCE: Roper washer wont empty
the pump is not working
Posted on Oct 28, 2008
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Posted on Aug 12, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
My machine will fill & go thru a wash cycle but wont rinse or spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Feb 08, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
