Question about Maytag MDB9100A Dishwasher
What is the proper water temperature for maytag mdb9100aww?
My dish washer stops 4 minutes into a wash cycle and then just clicks
SOURCE: maytag dishwasher mdb56000aww
It seems that your motor on the dishwasher is going out, like mine has just done. My explanation is that it sounds like something is grinding on glass or as if a bunch of mice are making noise. Eventually, the motor will not run any more. What will happen is that the dishwasher will fill up, then make a loud humming noise, while the heating element is making the water near the heating element sizzle. Now what you have is a possible fire hazard which compounds the problem with the dishwasher. Get rid of it, take the loss and live like my grandmother used to, without having a dishwasher. That is the best advice I can give you.
Posted on Jun 07, 2008
SOURCE: Stops in the middle of the wash cycle
HAVE THE SAME PROBLEM WITH THE SAME MAYTAG MODEL DISHWASHER. THE PROBLEM IS WITH THE CONTROL PANEL ASSEMBLY HAVING ONBOARD COMPONENTS NOT SODERED CORRECTLY TO THE MAIN CONTROL BOARD. THESE LOOSE OR COLD SOLDER CONNECTIONS HAVE TO BE REHEATED,RESOLDERED WITH A SOLDERING IRON . THE ON BOARD COMPONENTS THAT I WAS HAVING PROBLEMS WITH WAS THE BLUE BOX LOOKING COMPONENT,SOLID STATERELAY, AND THE RAISED RESISTOR,HAS COLORED BANDS AROUND IT. THESE COMPONENTS ARE LOCATED ON THE LEFT SIDE OF THE PRINTED CIRCUIT BOARD FACING THE DISHWASHER LOOKING OVER THE TOP. TO MAKE THE REPAIR, TURN OFF THE CIRCUIT BREAKER TO THE DISHWASHER, OPEN THE FRONT DOOR AND REMOVE THE 10 SCREWS THAT HOLD THE DOOR TOGETHER. THIS WILL ALLOW ACCESS THE THE CONTROL PANEL.. IF YOU DO NOT FEEL QUALIFIED TO MAKE THIS REPAIR USING A LOW WATTAGE SOLDERING IRON YOU CAN ORDER THE CONTROL ASSEMBLY LED FROM PARTSSELECT.COM. FOR ABOUT 100 DOLLERS. THEY ARE ABOUT THE CHEAPEST. FOLLOW THE ON SCREEN INSTRUCTIONS TO ORDER THIS ASSEMBLY.THE ASSEMBLY PART CAN BE FOUND IN THE CONTROL PANEL PARTS ILLUSTRATION. WHEN SEARCHING FOR THIS PART YOU MUST SEARCH USING YOUR DISHWASHER MODEL NUMBER. THIS INFORMATION CAN BE FOUND ON THE LEFT SIDE OF THE TUB OF THE DISHWASHER AFTER OPENING THE FRONT DOOR. ALSO, WHEN LOOKING FOR THIS PART IT WILL BE LISTED TWICE,AS SERIES 10, OR SERIES 24. YOU MUST ORDER THE CORRECT SERIES. THE SERIAL NUMBER ON THE SAME PLATE THAT THE MODEL NUMBER WILL PROVIDE THIS INFORMATION. IF YOUR SERIAL NUMBER STARTS WITH A 10 ORDER THE SERIES 10, WITH A 24, ORDER THE SERIES 24. WHILE YOU ARE ORDERING CHECK YOUR LATCH HANDLE, THE SIDE PIN WAS BROKEN MAKING IT HARD TO OPEN THE DISHWASHERS FRONT DOOR. ONE OTHER THING YOU MIGHT WANT TO CHECK IS THE FLOAT SWITCH OPERATION. MINE WAS STICKING. TO ACCESS THIS REMOVE THE 4 SCREWS THAT HOLD THE PANEL .THE FLOAT SWITCH IS LOCATED TO THE LEFT.WITH THIS PANEL REMOVED CHECK FOR ITS FREE NONSTICKING OPERATION. IT CAN BE DISMANTLED AND CORRECTED. A SERVICE SHEET IS LOCATED, ATTACHED TO THE INSIDE OF THIS PANEL.IT HAS GOOD TROUBLESHOOTING INFORMATION INCLUDING A AUTOMATIC FUNCTION TEST.THIS TEST PROVIDES A DIAGNOSTIC ANALYSIS THAT WAS EXTREMELY HELPING FOR ME TO DETERMINE MY PROBLEM AND CORRECT THE MALFUNCTION CONSIDERING I AM NOT A APPLIANCE REPAIRMAN. I HOPE THIS INFORMATION IS BENEFITICAL. REGARDS.
Posted on Jun 21, 2008
  • 1632 Answers
SOURCE: dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
Posted on May 14, 2009
joe_lishman
  • 192 Answers
SOURCE: I have a maytag MDB6100 with 2 problems
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Posted on Mar 26, 2010
heatman101
  • 43501 Answers
SOURCE: I own a Maytag Quiet
The old soap maybe working better but I am wondering about the heating element and if it is keeping the water hot enough to work efficiently with the newer soaps....
It is more critical then ever for the water to be hot when it comes in initially and to be keept at 140 F or more during the wash and rinse cycles...
I would do some checking as to the water temperature when it fills and after it is washing towards the end of the cycle...
You may also have a problem there that is intensified by the terrible new soap chemical makeup...
heatman101
Posted on Feb 05, 2011
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Sediment is collecting in the bottom and on the dishes. I have tried a cleaning cycle but it doesn't work.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
Sep 25, 2011 | Maytag 24 in. MDBH750AWS Stainless Steel...
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
After a cycle, we get white ugly streaks/film on glassess
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
May 11, 2011 | Maytag Dishwashers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
Feb 22, 2011 | Whirlpool Dishwashers
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Maytag MDB9100A Dishwasher Logo
18 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
