Question about Dodge 2007 Grand Caravan
Why is the front passenger tire rubbing when braking?
Checked wheel well and strut and found no marks from rubbing
  • 7 Answers
SOURCE: 1998 Dodge Ram 2500 V-10 2wd
check your tires for rubbing on fender well
Posted on Mar 19, 2009
  • 490 Answers
SOURCE: Just trying to find out what a light rubbing sound
Jack the car with the tire on and do the same test you probably will get it.be careful not to get under with out proper supports.
Posted on Aug 11, 2009
Audioaholic
  • 376 Answers
SOURCE: Front end vibration sounds/feels like tire rub but
have the hub bearings checked out by a certified mechanic, good luck
Posted on Sep 11, 2009
Testimonial: "Quick reply and right on point. "
  • 57 Answers
SOURCE: 1998 dodge neon front disc brakes
Does your car have rear disc brakes? If so, it is likely a failure of the emergency brake that is inside the rear disc.
Posted on Sep 22, 2009
alicantecoli
  • 22246 Answers
SOURCE: Passenger front power window doesn't work. Could
wires in door to door frame damaged?? as for oil smell try the breather pipe from the rocker cover to the air intake ,sometimes thay have a gauze filter in the pipe and its gets blocked
Posted on Mar 08, 2010
Rubbing noise from the passenger side of the car not sure if it's the back or front I can only hear when I am doing under 20
Diagnosing noises is hard enough when you are in the car or truck, but over the internet is nearly impossible. I suggest you have a local tire shop like Wheel Works drive this and see if it may be a brake or wheel bearing issue, they likely will do that for free.
Aug 02, 2016 | Cars & Trucks
My front passenger wheel makes a rubbing noise at 50 mph
You just need to have a mechanic or someone look at the front end. Has it been happening long enough to cause any odd tire wear on the tire? If the front end alignment is off, you could certainly get a lot more road noise, but even a badly worn tire would cause some noise.
If the tire is actually rubbing against something, and you hear it at 50 mph, that seems to indicate badly worn suspension parts- like ball joints or struts...so you should consider a good front end alignment shop and tell them the condition. They can check the tires and the front end as well. A reputable shop would check all that anyway, to make sure that the alignment job will actually keep the front end true.
Mar 30, 2015 | Cars & Trucks
Front passenger wheel is in at the top by 1/2 inch rubbing noise started when making left turns. I think wheel hub assembly is bad. Also inboard brake pad completely worn down. Can bad struts cause this?
Sounds like a bad hub/bearing, could also be a front axle issue though.
I have never heard in my almost 15 years as a mechanic of struts causing one pad to wear uneven, this more sounds like an issue of one of two things, bad caliper, or when you had your brakes replaced whoever did the job did not replace that pad.
May 20, 2011 | 2004 Oldsmobile Alero
Rubbing coming from front passenger side tire?
I presume that the tyre you have replaced is with the same specification size as on the either side, If so you need to check if the tyre is rubbing against the mudflaps or the mudguard specially when the side is loaded or the wheel is turned to one side. Lift up the side with a jack, turn the wheel to either side and check if there is enough gap on the sides. If you had replaced the tyre after a burst/puncture, had run the car after this had happened, then the wheel alignment must be looked in specially for the tow in/ out. Check for the wheel position using a thread held against the rear wheel and the front wheel postioned with a slight inner view, check the wheel from the top to bottom with a plumline. You will get some indication if there had been any shift in the chassis or the suspension. press down the side up and down to hear any creaking, if so check on your suspension parts, the lower arm, the roll bars and the strut/ shock absorbers. You have the problem lurking around here. Hope my advice helps you out. Good luck good day
Jul 07, 2010 | 2006 Ford Focus
Metal on metal sounding clicking noise while the wheels are turning but only on the frot driver and passenger wheels. What is going on? It started out only on the passenger side and then after the tire...
Is the noise a screeching high pitch or a growling low pitch?
It sounds to me that the CV joints might be bad and you need brakes.
high pitch would be the brake warning tabs
the low pitch would be the brake pads are gone and you are on the rotors gringing away metal
May 21, 2010 | 2000 Nissan Altima
Since my front struts were replace, I've had this rubbing sound coming from my front end. I've had my brakes and struts checked (by the shop that did the replacement) and have been told there's nothing...
Rubbing noise or grinding? Is it louder going around corners? It sounds like it could be the wheel bearings, and if it is indeed the wheel bearings, then yes, you need to get them replaced asap. Wheel bearing failure can cause the wheel to come off of the vehicle, hub and all.
Feb 04, 2010 | 2002 Chevrolet TrailBlazer
Front wheel berings 2003 silverrado 1500 4 wheel drive describe procedure to change out
reomve tire securing the vehicle with tire hanging at it's lowest possition, remove the brake caliper & brake disc , remove nut lock on axle also axle nut , mark and remove strut bolts and push strut out remove ball joint lower bolt and use a fork ( tooling) seperate from hub slide hub off of axle , reverse steps to replace .
Aug 22, 2009 | 2003 Chevrolet Silverado 2500HD
Steering wheel vibrates thumping noise
At what speed do you feel the shake and does it only happen when you apply the brakes?
Mar 02, 2009 | 1995 Nissan Maxima
I have a 2001 grand am that makes a rubbing or grinding noise from the front end. I have some vibrations in the sterring wheel as well. this is not noticable until the car is above 30mph.
Your front struts may be bad,There is a rubber seat at the top of the strut that can start to bind while driving and turning. Replace struts and realign front end.
Jul 27, 2008 | 2001 Pontiac Grand Am SE
Dodge 2007 Grand Caravan Logo
26 people viewed this question
Top Dodge Audio Players & Recorders Experts
Betty Pearl
Betty Pearl
Level 1 Expert
Jeff Brewster
Jeff Brewster
Richard Warren
Richard Warren
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
