Question about HP Officejet 5610 All-In-One InkJet Printer
Our HP Officejet 5600 won't receive faxes.
The error messages that come up are 244 and 232. What does this mean?
  • Anita Loconti Jun 22, 2009
    I know it is not working, that's why I asked what the error messages meant!
  • 30 Answers
Here is the answer to your question.
Error code 244 can mean any of the following things: :
1. You or the person sending the fax pressed the STOP key , causing the session to stop before completion.
2. The fax machine on the other end determined that there is an incompatibility with your machine and the one you are sending to and stopped the fax session.
To fix this you can try the following things. Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Make sure the fax machine you are sending to can accept and use polling.
  • Select a slower "receive" speed.
  • Enable or disable the ECM setting.
Error Code: 232
1. Can mean that a communication failure has happened between the two machines.
2. It may also mean that the user of the FAX machine you are sending to has pressed the STOP key
3. If call waiting is enabled, it may cause this error. Disable call waiting on your phone line, if you have a fax machine connected to it. The click or beep on the line that indicates you have a incoming call, can STOP a fax session.
4. Another cause of this error code is that the power was interrupted to the machine you are attempting to send a fax to.
Things you can do to solve this problem: Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Try disableing ECM. However, this may reduce the quality of your faxes.
  • Ask the person you are sending the fax to to set the machine to receive at a slower speed.
  • Try the fax again at a different time, incase it is a problem with the phone line.
  • If you phone lines are old, or there is static on the line it may cause trouble sending a fax.If this is the case you will need to contact your local phone company or whoever is responsible for servicing your phone lines.
Posted on Jun 24, 2009
  • tweety607
    tweety607 Jun 26, 2009
    Please let me know if this was helpful to you.
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab72
Posted on Jul 17, 2009
  • 121 Answers
Hi
This error appears cwhen your fax is not working properly.WE can help you to fix it out if you can visit at----http://tinyurl.com/ng46w9
Posted on Jun 22, 2009
How would i get the fax report
from the user manual:
The default fax confirmation setting is Every Error. This means that your
HP Officejet prints a report only if there is a problem with sending or receiving a fax. A confirmation message indicating whether an item was successfully sent appears briefly on the front panel display after each transaction. To have a confirmation printed for every fax, follow these instructions.
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press direction right button until Every Fax appears in the second line of the display, and then press OK.
The HP Officejet will print a confirmation report every time you send a fax informing you whether the fax was sent successfully or not.
Enjoy
Christopher
May 21, 2012 | HP OfficeJet 4255 All-In-One InkJet...
Wont send message. Error no 442
This error indicates that the receiving machine (receiver) cannot receive the fax you just sent. The reasons might be unexpected shutdown of the machine (Receiver's machine) just before it completely received [or partially printed] the file you had sent or power failure during the process.
Another reason is, when we send color fax from Hp machine to another Machine (non-hp), this happens due to incompatibility issue.
Solutions are;
1. Restart both the machine after deleting the recently sent/received fax.
2. Send black and white only, not color.
3. Try again after the phone line seems not much busy which means when there's better transmission capability.
Good luck.
Thanks for using FixYa.
Jul 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't receive faxes
well... check the telephone cable or conector...Rj11 conectors...
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet v40 - Not Faxing or Receiving
I have checked all my connections and my hp office jet v40 is giving the message off the hook though the phone it is connected to is not off the hook.
Aug 14, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
FAx Error
I understand that you are receiving the error "fax not sent" and the transaction report Error 389*. while sending fax.
The issue that you are experiencing is due to communication, however please follow the instructions from the below article to get the issue resolved.
Here is the web document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=buu02549
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue that you are experiencing with.
Regards,
Lawrence
Feb 06, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
1,093 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
