Question about Refrigerators
Fixya appliance I've been trying to find an appliance repair place to help me fix my fridge. What is something I should ask and look for in a repair place? I'd really like to have it fixed and not have to buy a new one any advice helps. I've looked at http://www.rtcappliances.ca/AboutUs.aspx, but would like some more advice.
    Novelist:
  • 157 Answers
I have seen appliance repair websites where technicians assist over the internet. in their spare time. as far as a choice for a technician to go-to the problem, you must call and ask questions to see if they meet your expectations. sometimes when faced with a solution for a problem you must trust.. if you don't know who? call the place you bought it and ask whom they are having perform the best effective repairs
Posted on May 09, 2014
  • dan lincoln May 09, 2014
    i discussed my frige with a tech on one of those websites, he was unreachable for telling me how to fix one but discussing the problem... the thing he told me not to do was the adjustment screw that fixed it. couldnt get him to admit it but he helped me by making me go look again and again.
  • 1462 Answers
SOURCE: Auto defrost not working correctly
the tray at the bottom which collects defrost water usually has its own heater or a section of the main heater runs close to it. check this part of the heater has continuity. an old trick as well which sometimes works is to wrap some copper wire round the heater and lead this to the drain hole. conductiuon of heat thro the copper helps keep the drain clear. this is a common problem across all makes
Posted on May 08, 2007
refritech08
  • 149 Answers
SOURCE: WARNING FRIDGE
does the freezer side freeze up also? i suspect if unit uses electronic sensors probably the thermostat sensors in the refrigerator section is defective. possibly there can be a thermostat board also you probably have to check diagrams.
Posted on Apr 19, 2008
catriver
  • 878 Answers
SOURCE: GE GSS22SGMC BS s x s freezer frost build up
Jake, the green wire is the ground, just attach it to one of the screws the secure the cover plate. As far as you ordering both the heater and the board, you have it covered. Catriver.
Posted on May 30, 2008
  • 115 Answers
SOURCE: fridge freezes food even though its set at warmest temp
what it sounds like is either your damper is stuck or your damper motor is bad it will probably be in the top left of your refrigerator side
Posted on Dec 30, 2008
  • 2920 Answers
SOURCE: FRIDGE NOT COOLING
you will want to call a service tech to get it fixed...they can fix it faster and probably cheaper
Posted on Jan 21, 2009
The compressor of my GE PFE 29PSDASS floor model comes on for a few seconds then goes off. The lights remain on. What is wrong?
Refrigerator Repair Help ' Appliance Aid
www.applianceaid.com > ... > Refrigerator Help Section
I heard a sizzling noise inside my freezer section and it looked like something ... Myfridge makes a bang noise when it shuts off; My Frost free fridge will not run at all; Myfridge is making screeching/squeak noises; My GE SxS fridge door has ... an amp meter, each compressor is rated in running amps ( see model/serial tag ...
GE Refrigerator Repair Online Manual ' General Electric ...
www.appliancerepair.net/ge-refrigerator-repair.html
FREE ONLINE GE refrigerator repair manual - Diagnose and troubleshoot ... to know basically how the bloomin' thing works, and then get on with fixing it? ... Chapter 5: GErefrigerator problem: Refrigerator is not cold and compressor is ... Do you have somequestions that you would like to ask a professional GE repairman.
Dec 17, 2015 | GE Refrigerators
Rubber seal around fridge door twisted.can it be replaced
Michael,
Yes, you can replace the gasket around your fridge door. If you put your make and model in, they did not come through to our screen, so we do not know what brand or model you have. There are several websites online that you can order parts from and I would suggest checking prices on those and check with a local repair parts place if you have one near to see how they compare with the online places.
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Water Filters Lawn Garden Appliance Parts
PartSelect Appliance Parts and Repair Help
These are a few places you might try.
Jun 12, 2015 | Refrigerators
Fridge dosen't seem to click off as much when it gets to temperature like it used to do, what can I do?
Try verifying the temperature range with a thermometer. For most fridge's you should see something like a low of 32 and a high of 40. Those would represent the turn off/turn on points for the compressor - that part that actually makes the fridge cold.
If it's swinging much outside those rages, the thermostat in your fridge is suspect. For most fridge's the thermostat is the know you turn to adjust the temperature. It usually has an attached wire/temperature probe that runs down behind a panel in the fridge and senses the temperature so the thermostat can command the compressor to turn on or off.
If it seems like the compressor might be at fault check with the manufacturer's website and you might find a parts diagram and identify the part. Then you can either call a repair technician or try replacing it yourself. You can purchase replacement appliance parts at many places on the Internet such as this site: Search Over 2 1 Million Appliance Parts
Good lcuk.
Mar 10, 2015 | Refrigerators
I have a max fridge cooler12 volts but i lost the power cord please help to found this solution. Thanks ve a max fridge 12 volts but i lost the power cord please help to resolve this problem
Email the company of the brand you purchased. Ask them where to buy the part. Cords for appliances like these are usually standard. The availability depends on where you are in.
Sep 03, 2013 | Max-Fridge STC55926 / STC55927 / STC55928...
I have a Maytag MZD2665HEW that just stopped working. The fridge is about 5-6 years old and we have never had any trouble at all. You can still hear it clicking like it wants to start cooling but...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one.
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Refrigerators
Neither refrigerator nor freezer cooling at all. Relatively new appliance and power to it not a problem as light bulb in fridge comes on and you can hear the fan.
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Sep 09, 2010 | Magic Chef CTB2125 Top Freezer...
We just replaced a GE defrost timer we plugged our fridge back in now fan will not turn on
OK no doubt you changed the defrost timer but the PSS26MSRSS uses a motherboard to decide when to defrost. You must have a different model than the one listed. I will help you if you like so click here to search=> Appliance Model Number Locations if your model is the model listed here I will be totally shocked. Ethier way I am here to help so don't give up. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How can I download a electrical diagram for a
I believe this what you were asking for=> APPLIANCE REPAIR PARTS GLOBAL click on diagram to enlarge, If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze Sea Breeze
Feb 02, 2010 | Refrigerators
Broich Commercial freezer ~ manual lost
I just turned it off and pulled out the super defrost button. I used towels not the drainage plug since I couldn't find a pan of any sort.
Also...very funny comment about my husband taking care of it!
Feb 08, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
