Question about Scunci 52033 Canister Wet/Dry Vacuum
What is the cost of Battery # 040715x?
What is cost of Battery 040715x model 52069
I have a scunci rechargeable wet and dry vac. Model 52069. I plugged it in to charge green light turns on. Couple hours later I unplug it and push the button nothing. Need instructions or manual.
Most likely the rechargeable battery needs to be replaced.
Unfortunately, I haven't been able to find a battery pack listed anywhere. You'll probably have to have a company like Batteries + Bulbs (In the USA) take it apart and replace the battery pack.
Nov 11, 2016 | Scunci Vacuums
Replacement cost for comparative vacuum model 38047990 serial #D00603923
Replacement cost for comparative model depends on how old the model was. A newer model may not be near the same as an older model.
May 03, 2016 | Kenmore Vacuums
Do you have batteries for a Shark sweeper model # V1945Z
I need a battery for SCUNCI # 52033 Vacuum cleaner.
BATTERY # 040715X
Come on someone help me
Bob
May 19, 2014 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I have an Accu-Time Electronic Clock Model #40240. Made in China, but have no idea how to set the time/date/ect. Is there a manual I can download?
It can't be done. The Accutime 40240 has a 3V lithium battery behind the 9V compartment that keeps the time should the clock lose AC power or even when the backup 9V dies. If however the 9V is removed, the AC power is disconnected and the lithium battery drains, there is no way for the end user to reset the time. There is a small data port in the 9V battery compartment which is how they initially set the time IMHO but good luck finding a way to do that outside the factory. Besides, these clocks are so cheap its probably less cost to get another clock rather than replace the batteries
Apr 04, 2011 | Vacuums
I need a battery for my cordless vacuum Model No. UV-610 72V DC EURO-PRO X. Please let me know price and how to order.
Do you has any of the following model # listed on the unit?
Shark UV610, UV610BL UV610C
THE ID TAG on the battery should be label as Replaces XBP610
You can order the battery pack via eBay for $28 by linking HERE.
Factory direct will double the cost.
Jan 27, 2011 | Vacuums
Is it possible to replace the battery (loosing charge fast, weak power) for Electrolux stick vac EL 1000? Wher to buy the battery an dhow much cost? Thanks LJ
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web.
Jan 12, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I can't find the charger to my Shark rechargeable sweeper Model V1700Z. Where can I purchase another one? Thank you.
well the cost of the battery is almost the price of a new one at Walmart 30.00 new.
But if you want to get a new battery. Radio Shack will get you one, they are know for there battery selection. talk with manager to get the best results.
Jan 01, 2011 | Vacuums
There is nothing on the screen of the pedometer, what ever I press. Do they run on a battery and if so can it be replaced? There's no apparent place to fit a new battery!
Pedometers run on a battery, the type depends upon the exact make and model which you have failed to mention.
Many cheap giveaway pedometers are not designed to have the battery replaced but it's usually possible to carefully prise the case apart if it's not screwed together. Some are glued together in which case you'll need a razor saw: if you have to buy a razor saw then it's cheaper to just replace the pedometer. You'll often find that with cheap disposable pedometers that the batteries actually cost more than a complete new unit with batteries included.
More expensive pedometers will always have a clearly defined battery access point, even if it's just a matter of undoing a few screws to separate the casing..
Sep 21, 2010 | Vacuums
Won't work after being charged for hours and hours
The odds are quite good that the battery's life has ended and would need to be replaced. If you provide a make / model number, I would be happy to check availability of a replacement battery as well as cost. I have found in the past that in many cases, the cost of the battery exceeds the value of the entire unit.
May 07, 2009 | Vacuums
Battery or ?
If this model is under 1 year warranty, I would suggest that you take it to a warranty repair shop or that you ask for a replacement. with a Return Material Authorization (RMA) at no further cost to you for shipping.
Jan 10, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Scunci 52033 Canister Wet/Dry Vacuum Logo
29 people viewed this question
Top Scunci Vacuums Experts
JoeVacs
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
