Vulcan Bonaire ducted heater fires up then stops before the fan turns on, it does this a few times before it starts working. Checked the diagnostic light and it flashes 7 times for error code 7. Have replaced flame sensor but problem is still there. Any suggestions?
    Problem Solver:
  • 16 Answers
Hi Vulcan Bonaire,
Is this a ducted gas heater or a free standing gas heater???
Posted on Jul 03, 2014
SOURCE: goodman gmp075-3 led blinks 5 times
I Also have the same and other problems with my furnace model # GDS80703AXBB. First the LED kept blinking 4 times and I too jumped the primary limit, that didn't kelp. After several attemps I moved the wires going to the circut board and everything starting working again. After a week It stopped working again, so I pulled the plug out of the circut board checked all wires for for a bad connection plugged it back in. Now the LED blinks 6 times again I move the wires. Then the LED blinks 3 times. Then the transformer burns out. I have burned out 2 transformers and I have ordered a new circut board.
Posted on Nov 15, 2008
SOURCE: I have a similar problem
I just went into the Bonaire website and downloaded their FAQ on gas ducted heating from their support link. Their instructions are pretty easy to understand.
Posted on Sep 09, 2009
johnsonr1
  • 91 Answers
SOURCE: lennox lf24 garage heater, starts then shuts down.
Here is a link to the manual for your unit heater:
http://tech.lennoxintl.com/C03e7o14l/mk6x6w5J5/503526e.pdf
The 4 flashes is a high limit or roll out switch is open. There are 2 or 3 little brown or black button looking switches with a little button on the top and a wire attached to each side. Press the button on each, you may hear a slight "click". If you do, that is the one that was open. Hope this helps.
Posted on Nov 04, 2009
  • 3087 Answers
SOURCE: ADP Garage heater model CUHP - 45A-3 LED flashes 4
Hi jump out the switch high limit or rollout it should start up
Posted on Mar 19, 2010
  • 674 Answers
SOURCE: pilot on, gas fires up, no fan comes on.
Sounds like you are talking about the indoor fan that circulates air through house. Turn the unit off and make sure the fan rotates freely. Next check the capacitor for the fan. If it looks swollen its probably bad. If it doesn't look swollen then you will need a multimeter to check it with. If that's ok then check the fan relay. Let me know what you find.
Posted on May 30, 2010
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
Jun 20, 2016 | Heating & Cooling
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
Vulcan ducted heating system 530 E (5 years old) have replaced AAA batteries on remote control but still not working. Thanks Michael
You have to recode the remote to the heater if the batteries have been removed for more than 3 minutes. On the comfort control will the remote is in a off state turn the heater off at the power.
While off press and hold the up button and the on/off until code appears then release buttons and turn the power back on to the heater.
When code disappears from the remote turn on the remote set the temp higher than current temp and combustion fan should start up then heater will fire up.
If not repeat process as they are easily corrupted by other remotes.
Download control manual from - http://www.bonaire.com.au/support/documentation/owner/default.aspx
Set / check fan speed or it may overheat.
May 17, 2011 | Heating & Cooling
VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Dec 31, 2009 | Heating & Cooling
Sep 08, 2009 | Heating & Cooling
Wiring diagram required
Just wondering if you h
Apr 19, 2009 | Washing Machines
Heating & Cooling Logo
479 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
