Question about Great Northern Popcorn Roosevelt Eight Ounce Antique Popcorn Machine in Red
What kind of lightbulb goes into my great northern popcorn machine
    Master:
  • 434 Answers
Does it have a bulb in it now? Try an appliance bulb you put in your over. They are around 40 watts. It may work if it has the correct socket.
Posted on May 09, 2014
Ls80t hot water goes hot cold hot cold heating is ok
http://waterheatertimer.org/How-to-fix-water-heater.html
What kind of water heater do you have? Boiler, indirect?
What brand and model?
Or is this a HVAC unit?
Gene
Aug 17, 2014 | Water Heaters
Bosch Aqua-star tankless water heater had water on gas valve, dried gas valve, I have a spark but will not light
Water in the gas valve is DANGEROUS! The major question is did the water come from a leaking heat exchanger or the product of combustion? If it is from the heat exchanger it may be covered under the warranty (if the installation is proper). If it is from condensate in the flue pipe, it is from an improper installation. If you go to bosch-climate.us you can find a service provider in your area. I service a very large part of NY, some of NJ (Northern) and all of CT.
Sep 05, 2013 | Bosch & Tankless LP Hot Water Heater
Atwood g6a-be lights but goes out in 3-4 min.
mine is pretty new about a 1year in halve to two years old. i light with lighter it lights burns great then acts like propane cutts out then burns low then cuts out kinda acts like propane pressure cuts out in the valve but i can relight 30seconds later same thing. i have checked stove it burns great. is it in the waterheater propane valve. need help pease i need a cheap fix layed off right now. thank you dave
Sep 20, 2012 | RTO Atwood Water Heater - 6 Gal LP
I have a Park Model RV with a Rheemglas Fury model 81VP205 with no bottom drain. How do I drain the water heater to winterize for the cold Northern Winters?
Make sure it's off (hydro) and open drain at cold line going in bottom wherever you find a drain (usually close to it) going down through floor and outside under trailer. Follow cold line back until you see a line "T" and one line going down under trailer, and open it up underneath. Then open pressure relief valve at top of tank to allow for faster draining .
Oct 14, 2011 | Water Heaters
The heater heats the water just fine, but after a short while it shuts off and the water becomes cold.
sounds like the unit cant keep up. What I mean is that the water going in is to cold to begin with. All tankless units efeciency is based on the temp of water going in, which their rated between 40-50 degrees on average. Now if you live in the southern part of the country, U.S., thats fine. But if you live in the northern part, it will not work. Im in Vermont and have people in the store about once a month looking for an electric unit, because they dont have gas, And I have to do my best to talk them out of it.
Mar 16, 2011 | Stiebel Eltron Tempra 24 Electric Hot...
My waterheater continues to go off. It began yesterday. I have had to relight the pilot 6 times. It seems as if it will work until someone actually needs hot water, then will go off.
problem is on pilot assembly that goes from temp control to burner inside..kind of expensive so u should check to see if there is an 800 number to check wrrnty info..temp control box also goes bad also
Nov 25, 2010 | Whirlpool Water Heaters
Hi Our gas water heater is not igniting
you need to replace the thermocouple its an electronic device that keep the gas flowing . the pilot light is always on and the thermo couple controls the flame. if it goes bad the flame goes out and the burner wont come on to heat the water, they are easy to replace and available at all home depot or a lowes kind of store.
Dec 01, 2009 | Water Heaters
The pilot light on my gas water heater continually goes out. I can re-light the pilot and get it going. The gas burners goes on runs for awhile. I'm assuming when that when the temp hits the desired temp...
getimage_new.asp?id=599586&imagetype=2&noimagetype=2&colorimagesize=2
The pilot assembly should look similar to the pic above. Depending on where you live, you may be required to hire a certified plumber to replace the parts. If not you can do it your self. Keep in mind if it's not staying lit you also need to check the thermostat and the thermocoupler before replacing the pilot assembly. There is a good chance it is just the thermocoupler going out. It is one of the first things to check when troubleshooting a pilot light problem with a gas water heater. A thermocouple determines if the pilot light is lit. If it's not lit, the gas valve fails. If that's the problem, replace the thermocouple.
  1. Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  2. Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  3. Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  4. Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  5. Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
Jul 09, 2009 | Northern Tool Water Heaters
Takes long time to heat then goes from hot to cold.
I know that this is a great answer but with out being there its hard to answer you call there tech support they are great, I have had to call they from jobs before they can help
Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
Feb 03, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Great Northern Popcorn Roosevelt Eight Ounce Antique Popcorn Machine in Red Logo
56 people viewed this question
Top Great Northern Popcorn Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Great Northern Popcorn Water Heater Expert? Answer questions, earn points and help others
