Question about Bosch Nexxt 500 Dryer
My delicates/low heat button doesn't work on Bosch Nexxt 500 dryer
SOURCE: Bosch nexxt 500 series dryer
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
Posted on Dec 28, 2009
heatman101
  • 43501 Answers
SOURCE: Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 28, 2010
SOURCE: my bosch nexxt 500 series electric dryer is not
We had the same problem. Cleaned out lint filter and still no heat. We took off the back (lots of screws and had to take top off to get back off). If you are looking at back - at the bottom left there was a red reset button and it clicked when we pressed it (when we pressed it again there was no click). Worked fine after. This solution came from internet. My brother-in-law changed setting to "extra dry"- we usually just used 20/40/60 setting. I think it overheated.
Posted on Oct 04, 2010
  • 39 Answers
SOURCE: Where do I find the
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
Posted on Mar 02, 2011
  • 25 Answers
SOURCE: bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Posted on Jan 18, 2012
My Bosch Nexxt 500 dryer stopped heating. All other functions work fine except heat. I've checked continuity on heating element & overtemp breaker- both OK. What else could be the problem? Fuse?
CONSIDER THIS
BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER
Maybe you don''t have power to both legs of your receptacle. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
Dec 14, 2015 | Bosch Nexxt 500 Dryer
Bosh 500 series dryer wont heat and rest button wont push in.
then u definately have a problem,and would be better getting a tech to look at it for u
Jan 19, 2014 | Bosch Nexxt 500 Dryer
I have a Bosch Nexxt 500 andjust replaced the heating element less than 6 months ago. A week ago it stopped heating up again. Took the back panel off, pushed the reset button but now when I turn it on, the...
Sounds like a bad thermal fuse or thermostat, check all of them with a multi meter for continuity. as for the heater going out I would check ur venting inside and out the machine. the fuses and heater blow out for a reason? Usually due to overheating issues? I suspect ur lint build up is the problem?
Aug 16, 2012 | Bosch Nexxt 500 Dryer
Bosch Nexxt 500 series dryer
Make sure the vent outside isn't blocked either.
May 21, 2012 | Dryers
Bosch nexxt 500 elec dryer has no heat to it
Jan 04, 2012 | Bosch Nexxt 500 Dryer
My dryer doesn't heat up any more, I would like to repair it by myself. Where do I find the replacement part on the dryer
Bosch sells parts online. The parts arrive at your home in about 2 business days after you place your order.
The website link: http://www.bosch-home.com/us/support.html
Sep 06, 2011 | Bosch Nexxt 500 Dryer
Er@verizon.netbosch eletric dryer nexxt 500 series no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 23, 2011 | Bosch Nexxt 500 Plus Dryer
Where do I find the reset button on my Bosch Nexxt 500 series dryer? The dryer will run, but no heat is coming out.
Mar 01, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
heatman101
Apr 27, 2010 | Bosch Nexxt 500 Plus Dryer
Bosch dryer nexxt, motor runs but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
hlg
Jan 24, 2010 | Bosch Nexxt 500 Dryer
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
