Question about Sport & Outdoor - Others
What are all names for a rectangle - Sport & Outdoor - Others
Need overload and a relay starter for refrigerator model wr1001
Type the brand name, model, and part you need in the rectangle of the search engine you use and it will show you sites to find the parts you need.
May 15, 2016 | Refrigerators
How many 7 by 12 inch rectangles, can be placed in a 100 inch by 66 inch rectangle?
You want the blanket to be 6600 square inches using 84 square inch rectangles. Dividing 6600 by 84 gives about 78 and a half.
Nov 07, 2014 | Home
How many squares in a rectangle has a perimeter of 40
That depends on the rectangle.
A 1x19 rectangle has 19 squares.
A 2x18 rectangle has 36 squares.
A 9x11 rectangle has 99 squares.
A 10x10 rectangle (a square) has 100 squares.
All of these rectangles have a perimeter of 40.
May 29, 2014 | Computers & Internet
What is the greatest perimeter that a 48 meter squared rectangle could have?
Infinite.
A one meter by 48 meter rectangle has an area of 48 square meters and a perimeter of 98 meters. A one centimeter by 4800 meter rectangle has the same area and a perimeter of 9600.02 meters. A one millimeter by 48,000 meter rectangle has the same area and a perimeter of 96,000.002 meters. A rectangle one micron by 48,000,000 meters has an area of 48 square meters and a perimeter of 96,000,000.000002 meters. Keep making the rectangle skinnier and skinnier without changing the area, and the perimeter keeps getting longer and longer.
May 01, 2014 | Computers & Internet
Perimeter of a rectangle
1 tile by 20 tiles - perimeter of 1+ 20 +1 + 20 = 42
2 tiles by 10 tiles - perimeter of 2 + 10 + 2 + 10 = 24
(can't make a rectangle with 3 rows)
4 tiles by 5 tiles - perimeter of 4 + 5 + 4 + 5 = 18
5 tiles by 4 tiles - perimeter of 5 + 4 + 5 + 4 = 18
(can't make a rectangle with 6, 7, 8 or 9 rows)
10 tiles by 2 tiles - perimeter of 10 + 2 + 10 + 2 = 24
20 tiles by 1 tile - perimeter of 20 + 1 + 20 + 1 = 42
So 6 different rectangles. Smallest perimeter is 18.
Jan 08, 2014 | Computers & Internet
If you know about area formulas of class 8 and 9,please solve my question?there is a circle.in the between of the circle,there is a rectangle of dimension 4cm and 3cm.if the rectangle will cut out what...
The diameter of the circle is the diagonal of the rectangle use Pythagoras this rectangle is a made from two 3,4,5 triangles, so the diameter is 5cm, the radius will be 2.5cm don't forget the BODMAS ordering rule (Brackets of Division Multiplication Addition and Subtraction) Also rounding to 2 decimal places. This solution is based on all four corners of the rectangle touching the circumference of the circle.
Area of a circle is P (22/7) i x Radius (squared ^2) ====> 22/7 x 2.5cm ^ 2 ====> 22/7 x 6.25cm
TOTAL AREA of CIRCLE = 19.64 cm^2
Area of the rectangle is length x width ====> 4 cm x 3 cm
TOTAL AREA of RECTANGLE = 12 cm ^2
The remaining portion is the circle area minus the rectangle 19.64-12 = 7.64 cm^2
SIMPLES brought to you by SpideRaY @ http://www.windowstipsclub.com
Jan 31, 2011 | Computers & Internet
Is a rectangle squared or cubed
Some wires got crossed here. A cube is a solid (a 3D object), whereas a rectangle and a square are 2D figures. You cannot compare a 2D figure with a 3D figure any more than you can compare say a parking lot and a highrise building.
A rectangle is a quadrilateral (closed polygon with 4 sides). In a rectangle, opposite sides are parallel and equal in length. In a rectangle all 4 angles are equal, each measuring 90 degrees.
All this is true for a square, except that all sides are now equal. So you can say that a square is a special kind of rectangle, namely, a rectangle with equal sides.
Hope it helps.
Oct 08, 2009 | The Learning Company Achieve! Math &...
A rectangle with sides parallel to the x-y axes and its left-lower corner at (0, 0) is being painted. The rectangle may be thought of as a flat-screen display with almost infinite resolution; initially the...
It would be "cheating" for anybody to do your "homework" from your computer-mathematics class, unless you submit your answer, saying that an EXPERT on FIXYA did all the work on your behalf.
Apr 14, 2009 | Microsoft Windows XP Professional With...
Dark Translucent Rectangle appears in front of picture
Go into the customer menu and find the "closed captions" heading. Within the closed caption you will find "TEXT". If you turn off closed captions or the text, whichever you menu lets you do, your rectangle will go away. Hope this helps
Dec 21, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Inst manual
The length of a rectangle is twice its width w. a second rectangle, which is 8 cm longer and 3 cm narrower than the first rectangle, has perimeter 154 cm. Make a sketch of the rectangles expressing all dimensions of w. Then find the dimensions of each rectangle.
Oct 03, 2008 | Texas Instruments BA Real Estate...
Sport & Outdoor - Others Logo
137 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
