How to I reset lamp timer on a RCa Scenium model numberHD50LPW175
    Master:
  • 687 Answers
I don't see a lamp reset in the owners manual. see web site:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
there is a phone @ to call 1-800-338-0376
Posted on May 09, 2014
SOURCE: how to reset lamp timer
While pressing the VOL- button on the projection display,
hold down the PIP button on the remote control
simultaneously for more than 5 seconds. You will see a screen pop up that says "Lamp time was reset to 0" and the lamp indicator light will go out.
Posted on Dec 24, 2008
SOURCE: I have a 50 inch RCA HDTV scenium model HD50lpw175
TRY THE BLACK LEVEL SETTING AND CONTRAST SETTING
Posted on Sep 04, 2009
asnowman
  • 788 Answers
SOURCE: how does one reset the lamp timer. modelpt-56dlx25
Panasonic2.gif Lamp timer reset.
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
asnowman
Posted on Oct 12, 2009
  • 145 Answers
SOURCE: How do I reset my lamp timer on a panasonic HDTV
go into menu.... and you will find lamp setting. reset it to zero hours
Posted on Nov 17, 2009
  • 1030 Answers
SOURCE: My RCA Scenium HDLP50W151 TV has no picture. It
do you here a whining sound when you plug it up. when these units are first plug up there is a part called the color wheel that spins during boot process. if it doesnt reach speed then the lamp never fires. It is a motor and anything that moves evientally stops moving. it would have to be replace if you can get the part
Posted on Dec 10, 2009
I need to reset lamp timer for RCA tv I already place bulb in
It sounds that you wish to know how to reset the lamp time after lamp replacement. If so, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Lamp replacement procedure, and lamp time reset details are given. google.com/+GopakumarGopalan
Nov 02, 2013 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA scenium model hd50lpw165. lamp went out- replaced it but tried so many times to turn it on before realizing the bulb needed to be replaced that it locked up. what to do?
http://www.tvtechcenter.com/board/links/rca/ATC311%20Training%20Manual.pdf
OK above is a service and training manual this is what engineers use to teach engineers how to fix sets like yours Use this an you may be able to repair READ THE SAFETY INSTRUCTION FIRST.
Apr 29, 2010 | RCA Scenium L50000 Television
RCA Scenium turn on tv with remote, on light flickers on and off
You'll probably need to replace the lamp, the approximate life of a lamp is between 4000 and 6000 hours depending on owners use. You'll find the lamp located behind the access dorr in the right side of the back cabinet, two hex screws hold the access door in place and two more hex screws hold the lamp cage. Once the screws are removed pull the cage assembly out and check the lamp side, you'll probably see the damage in the center of the lamp. If the lamp is the problem, you can find a goos selection at UED union electronic distributors, you can contact johnl@ued.net and provide him with your model number.
Apr 28, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium will not turn off an has no picture
Unplug the TV for a minimum of 2 minutes to reset it then try again. If you get no picture there is a possibility the lamp is no good.
Mar 02, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My RCA Scenium picture just went black out of no where. I can still hear sound, it will change input but nothing shows up on the screen.
Take the Lamp out and see if it is shattered. The access door is on the left rear of the set. Chances are the lamp is the problem. The Lamp cage has the part number on it.
I hope this helps,
Skyassoc
Dec 26, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Wont turn on and lamp has been replaced.
You most likely have to reset the lamp timer. If it gets maxed out it will not turn on till it is reset. Check your manual to see how to reset.
Sep 12, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
How do you change a RCA bulb on a Flat Screen Televison
GO ONTO ASK.COM AND ASK THEM OR GO ONLINE TO THE ADDRESS BAR AND TYPE:
RCA SCENIUM HD50LPW52 SERVICE MANUAL
OR
HOW REPLACE A BULB FOR RCA SCIENIUM HD50LPW52
ENTER
ROD
Feb 17, 2009 | RCA Scenium HD50LPW52 Replacement Lamp
The picture on my RCA Scenium HDLP61W151 61 in - was completed black
unplug both the TV and the cable box for 2 minutes then replug them in. this will reset the micros in both units. if there is still no sound check your SAP setting make sure its off.
Feb 06, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture
Assuming that the replacement lamp is good, you could be looking at a bad ballast (lamp power supply) or the switch on the lamp door itself could be causing the issue. The light engine also could cause an issue like that. I would have a technician look at it as this is beyond consumer repair.
Nov 25, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
