Question about Casio Scientific Calculator FX82
Reduce the decimal places
How to reduce the decimal places on my calculator, It currently shows 6 decimal places i dont need them to be six
  • Casio Master
  • 7,993 Answers
Press the MODE key a certain number of times until you get FIX. Select it. You will be asked to specify the number of decimal places (enter a number between 0 and 9). You can also choose the normal mode. However, if the result is too small or too large, it will be displayed in scientific notation.
Posted on May 09, 2014
SOURCE: I am trying to get
You should press SHIFT then MODE (setup). Then press 2. Done! If you want to change it back, just do the same again, but press 1.
Posted on Sep 01, 2008
  • 7 Answers
SOURCE: calculator won't show decimal places
Haven't heard of it giving nearest whole numbers before. But have you tried pressing SHIFT and then SETUP (upper right hand corner next to ON button) and then pressing 2 (LineIO)? Or perhaps you're in different MODE?
Posted on May 03, 2009
SOURCE: i dnt kno how to get the decimals off
dude i just found it out press mode CLR at the top 3 times then press the # 3 at the botton
it should say (norm 1~2?) when it does press the # 2 and there you go!!!!!!!
Posted on Jun 17, 2009
SOURCE: How to round up to 2 decimal places?
can you tell me the answer to this question
round 618 to two decimal places
Posted on Oct 13, 2009
  • 7993 Answers
SOURCE: I have Casio fx-83ES. I'm using it in Mode 2 -
You can configure it as you wish. Press [SHIFT][MODE] to access the (SETUP) configuration screen, then select [8:Norm].
You will be prompted to choose Norm1 or Norm2. To help you find out which is more appropriate to meet your concerns, I am inserting a screen capture from the manual.
Posted on Jul 18, 2010
I want to set the decimal place without using the decimal key--example: hit the 1234 keys and the shows $12.34
You can select the A (K . A) and then the # of decimal places (F 6 3 2 1 0) you want. So if you want to enter 1234 & it calculates 12.34, this will work.
Jul 22, 2011 | Sharp EL-2630P Calculator
Explain "CUT", "UP", "5/4"
CUT: Values are cut off to the number of decimal places speicified by the current Decimal Place Selector setting
UP: Values are rounded up to the number of decimal places speicified by the current Decimal Place Selector setting
5/4: Values are rounded off (0,1,2,3,4 are cut off; 5,6,7,8,9 are rounded up) to the number of decimal places speicified by the current Decimal Place Selector setting
May 04, 2011 | Corporate Express CEB95005 Calculator
How to change the decimal placement to more places? i currently only have 2 decimal places displaced
Press 2nd [FORMAT], type the number of digits you want after the decimal point or 9 for floating-decimal, then press ENTER 2nd [QUIT].
Mar 03, 2011 | Texas Instruments BA II PLUS Financial...
Convert .714285 to the fraction 5/7?
Say you have a repeating decimal number 0.714285 714285 714285 etc. You identify the period (the repeating part) and in this case it is 714285.
Y
ou count the number of decimal places in the period: here it is 6. Your equivalent fraction is
Fraction= period/(99...9) where the number of 9's in the denominator is equal to the number of decimal places in the period. For this case, that is 6.
Thus
0.714285 714285 714285 etc.= 714285 / 999999
Reduce the fraction and you will find 5/7
This technique works for a repeating decimal number where the period starts just after the decimal mark.
If the periodic part does not start right after the decimal mark there are modifications to be made.
Jan 16, 2011 | Office Equipment & Supplies
Only shows 1 decimal place!!
Press 2ndF TAB and then a digit specifying the number of digits you want after the decimal point.
May 23, 2010 | Sharp EL-501WBBL Calculator
When I try to divide numbers that would leave a remainder like 1 divided by 6 which should give me an answer like 0.16666666666 instead all it says for an answer is 1/6. it does say in the manual to input...
To convert from fractions to decimals, and from decimals to fractions use the [S<-->D] key. If you want your decimal results to have a fixed number of decimal places press [SHIFT][SETUP][6:Fix]. Screen shows Fix 0~9. Enter the number of decimal places exemple 3.
Dans ce cas 1/6 is displayes ase 0.167.
Hope it helps.
Sep 23, 2009 | Casio FX-115ES Scientific Calculator
Show two decimal places
Input the following and try:
  1. Press 2ndF and . the point button. This changes the screen to FIX DEG
  2. Press 2ndF +/- 2 Answer shown is to 2 dec. pl.
  3. If you want it to 5 decimal places, Press 2ndF +/- 5 answer shown is to 5 d.p. and so on
For normal, just take calculator out of FIX so just DEG shows.
Couldn't find you a YouTube video, so text will have to do.
crimsonnightt@hotmail.com
Apr 01, 2009 | Sharp EL-738 Scientific Calculator
I lost my decimal point
You need to be in add mode, and have 2 decimal places selected for the result.
To change to add mode, make sure the 'K . A' switch is in the 'A' position. To get 2 decimal places in the answer, move the selector in the 'F 6 3 2 1 0' switch to the '2' position.
You can see the above described at
this Sharp.com page which shows the users manual. The manual shows examples.
Mar 19, 2008 | Sharp EL-1197P Calculator
EL-1197PIII Sharp Calculator
move switch for decimal places to "add",or to number "2" for 2 fixed decimal places
Feb 28, 2008 | Canon LS-100TS Calculator
Casio Scientific Calculator FX82 Logo
65 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
