Question about Electrical Supplies
Overall I have a switch at each end of the garage with two lights in the roof in between. Sw (A), Lite (B), Lite (C), Sw (D). SW A & D work as three way. I want to change out Sw D to a wall plug a
Overall I have a switch at each end of the garage with two lights in the roof in between. Sw (A), Lite (B), Lite (C), Sw (D). SW A & D work as three way. I want to change out Sw D to a wall plug as the Sw is not needed. I have a Black (hot) and a Red & White. How do I connect plug to remain always hot?
  • 3,289 Answers
If this is what you've got:
Overall I have a switch at each end of the garage  - a1111786-3b67-43eb-a2de-7ac2c5a3e864.jpg
"S3" are 3 way switches, black screws are the common or shunt. (Adjust colors of wires to what you have).
You can easily change it to look like this:
All S3s are out. Replace one with an S1 (single pole). The other S3 is now the outlet. Silver screw for neutral gold screw for hot. Outlet is always on, S1 controls both lights.
Please note: There are several ways to wire 2 three way switches (S3) to control a light or two. This is just one with a way to change this method to the way you're look for. Your wiring may not allow you to do this as easily.
Posted on May 09, 2014
Had two 3way sw I added a new door to garage and needed a switch at that door so I took out one three way sw an planned to replace that 3way with a four way I ran 3 wire from new door to the new 4way
The 4-way can work with the two 3-way switches you have just fine. In fact here is the link for you that shows the connection:
https://www.google.com/search?hl=en&tbm=isch&source=hp&biw=1440&bih=686&ei=it9yWvjABZXGjwOc_4SoCg&q=3+way+to+4+way+switch&oq=3-way+to+4-way+&gs_l=img.1.0.0i30k1.1635.7177.0.9422.17.15.0.2.2.0.115.1138.10j3.13.0....0...1ac.1.64.img..2.15.1151.0..0j0i8i30k1.0.Q4mqL0_2bEs
Dec 23, 2017 | Electrical Supplies
The overhead light between the driver and passenger won't come on where do I find power for this light
Your instrument cluster light dimmer switch if turned to max, will click on the roof light..Some cars also have overhead light disable sw near light control panel. Also door sw around door where it closes
May 15, 2017 | Cars & Trucks
Using without parking break
Hi James,
Page 27 of the installation manual (http://www.wwstereo.com/_files/155788/documents/Kenwood--Manual.pdf) shows a connection to the parking brake light circuit. It is the Light Green wire labeled "PRK SW" shown below.
If it is connected the way it is drawn, the PRK SW wire is connected between the lamp and the switch that opens and closes depending on the position of the parking brake (set or not). 12 volts is always present from the battery to the top of the lamp. It passes thru the filament to the wire that goes the top of the parking brake switch. So, when the brake is OFF or disengaged, the lamp is off and 12 volts is present on the PRK SW wire to your Kenwood GPS. When you set the parking brake, the ground (symbol is the funny slanted lines under a horizontal line) just under the brake switch passes through the switch and changes voltage at the PRK SW to "ground" or 0 volts. When this happens, the ground on one side of the lamp with 12 volts on the other side of the lamp - make is turn on.
So, what does this mean? Simply tie the PRK SW wire to any grounded metal and the Kenwood will think the parking brake is always set - for as long as it is tied to ground. You can check it with a simple voltmeter to be sure. Set the meter to 12 volts or more, touch black lead to ground & the red lead to the PRK SW wire. Kenwood should only work when at 0 volts (brake set). Release the brake - meter shows 12 volts & the Kenwood shuts off.
I hope this helps & Good luck!
Apr 09, 2014 | Kenwood DNX570HD
1 -3 way sw installed with a 3 way dimmer without a load,test voltage on wires for light to make sure sw is working properly. with sw on 120V,sw off 100V?? why the voltage with sw off? All new wiring.
You will always have voltage through the black incoming wire unless you turn your circuit breaker off. This wire will be attached to the common terminal on the switch. Is this what you were testing?
The power comes in the common terminal and then is switched through, or on, and broken, or off, when the dimmer is clicked. Therefore, there is always power coming into the switch.
Hope this helps, if it does, please place a vote for me. Thanks,
Handie Andie
Mar 28, 2011 | Pass & Seymour Trademaster 3-Way 15 Amp...
Headlights, both low and high beams won't come on
Start, check for 12Vpwr. eng. comp fuse box 30A runs into the multifuction switch.
Head light sw. runs into the multifunction switch.
out of multi sw. pass. comp. fuse box 20A # 38 for high beam
out of multi sw. two 10A fuses #10 & #4 for low beam
make sure you grounds ar good G102 & G103
G102 LH front eng. comp.
G103 RH front eng, comp.
Sep 12, 2010 | 2001 Ford Mustang
I think i have a blown fuse my windshield wipers and sun roof does not work. Which number fuse would this be?
Look in the owners manual! It may tell in the fuses section under circuit protection! You can check all the fuses with a test lite or a volmeter ,be sure and turn on the ignition sw. to get power! Ptobably a 25 amp fuse! Check both sides of fuse!
Sep 06, 2010 | 1990 Chrysler New Yorker
1992 FORD E150 VAN - Drivers window goes up & down ok but .... PROBLEM: (With IGN. SW. ON) Passenger window goes down, but not up - using drivers (master) switch or passenger sw. I have (2) micro...
i think the problem is the drivers side switch ,what i do is to run a earth wire on the passenger side so it only works from the passenger side ,i rewired a american GM astro van about 2 wqeeks ago and i cannot remember how a done it for the life of me ,i know the switch had 6 connections and the ones from the motor ,went to the middle two ,power into the end one with a strip running to the other opposing end ,and the earth into the other end with connection into the other opposing end one ,if this helps
Aug 18, 2010 | Ford E-150 Cars & Trucks
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
1995 toyota camry stop lights are not working
If the fuse is fine and the bulbs are good you should check with a test light if power is being supplied to the terminals if the problem must be reached in the brake switch is on the brake pedal. Thank good luck
Jan 13, 2010 | 1995 Toyota Camry
BLACK & Decker Countertop owen Model: CTO 649 does not work
Try smallappliance.com for your parts or just google search "small appliance parts" and you'll see a few places that have B&D parts.
Sep 19, 2009 | Black & Decker CTO649 Toaster Oven with...
Electrical Supplies Logo
63 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
