Question about Various MFR 2002 Ford Windstar A/C Condenser
How do you 1999 grand marquis ho do you reset fuel pump switch
  • 151 Answers
Reset should be on drivers side in the trunk, may be under carpet/panel.
Posted on May 09, 2014
How do I reset the kill switch on a 2001 murcury grand marquis
If you are referring to the inertia sensor that kills the fuel pump power, then it is inside the trunk and has a reset button. Just press and hold the button and it will reset. Usually on drivers side of trunk next to optional air ride switch.
Jul 29, 2017 | 2001 Mercury Grand Marquis
On 1999 grand marquis, cut fuel pump assembly wires 3. On new one, the wires are different colors. How can i find out how to match them up
Match the location of where each original color goes to the same location on the new pump regardless of color and connect them. GOOD TO GO!
Dec 18, 2016 | 1999 Mercury Grand Marquis
Where is the fuel pump relay on a 1999 grand marquis the car will not start car started wit starter fluid so its not a ignition prob the car did start wit a jump wire on the fuel pump shut off switch
The fuel pump relay is in the powerbox on the drivers side of the car. It can be in a relay trio which is hung behind the powerbox and has a slide out access to the relays inside or it can be inside the big powerbox. Usually the cover has the relay name and position embedded in the plastic.
Apr 24, 2015 | 1999 Mercury Grand Marquis
How to to check power on the fuel pump on a 99 grand marquis
in trunk there is a enersia switch that may need to be reset. you can test for power there. 5 sec only after key is on. computer shuts down power if engine is not cranking of started.
Dec 24, 2012 | 1999 Mercury Grand Marquis
1999 mercury marquis wont start, turns over fine, think its the fuel pump, not sure.
Check the fuel pressure at the injector rail.Or hook it up to OBD II code reader, which should give the average fuel pressure.
Do you hear the fuel pump run for a second or two when you first turn the key to `ON' position? That means your fuel pump reset hasn't tripped(for collision purposes,but sometimes needs reset).
When all else fails, go to Ford and they will hook it up for 50-70 bucks and tell you what is wrong.
If you can give more details, post back and let us know. don-ohio (:^)
Nov 02, 2011 | 1999 Mercury Grand Marquis
99 marquis got spark got fuel starts with starting fluid relay seems fine switched
Can you hear the fuel pump come on when you turn the key on? First thing I would check is the fuel cut off switch located in the trunk on the driverside quarter panel.Sometimes this will cut off the fuel if the vehicle is jolted from a pot hole or collision. It's a little black box which may have either a red or black button on it.
Nov 29, 2010 | 1999 Mercury Grand Marquis
Fuel pump is bad but also no power to fuel pump and relay is fine, where could the problem be coming from
All fords have a fuel pump enertia switch usually located on the passengers kick pannel or in the trunk on the drivers side. have you checked the fuses under the dash and hood? how do you know the relay is good?
Aug 23, 2009 | 1999 Mercury Grand Marquis
1998 Mercury Grand Marquis Fuel Pump Replacement
you can try just resetting the fuel pump switch located in the car
the switch is originally in the car for in case of an accident, however, if changed, chances are you also have to reset it
in my 98 grand marquis, the switch is on the left side of the trunk
Jan 09, 2009 | 1983 Mercury Grand Marquis
Fuel pump relay location on a 1990 mercury grand marquis.
check the fuse .if the fuel pump was bad you blew the fuse . there is a inertia switch in the trunk or under the dash you could check . push the red button to reset relay should be under the hood in the fuse box check your book if you have one.
Nov 19, 2008 | 1990 Mercury Grand Marquis
Various MFR 2002 Ford Windstar A/C Condenser Logo
16 people viewed this question
Top Various MFR Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Various MFR Heating and Cooling Expert? Answer questions, earn points and help others
