Question about HP Pavilion dv6748us Notebook
How to get driver for cd dvd unit - HP Pavilion dv6748us Notebook
  • HP Master
  • 5,103 Answers
The optical disc drivers are part of the OS. The available drivers and software for Windows Vista, the original OS for the DV6748us are here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=3648284 . Select your version and click Next.
Windows XP and the subsequent versions of Windows all had the drivers for internal optical drives and most external drives in the Plug and Play control. You may need to go to the Device Manager and check the device status then manually update the driver. (For Vista, click Start > Control Panel (in the right hand column, then under Hardware look for the Device Manager link.) Expand the section for optical drives and look for a triangle with a red x or a yellow exclamation point. Right click on the device and click on the Update Driver button. If that doesn't work, try uninstalling the driver then shut down the computer. Check if Windows loads the driver correctly when you reboot. If you continue to have problems, the drive or cables might be bad. Consider getting a new optical drive (slim if you want to stay with an internal drive).
I hope this helps.
Posted on May 09, 2014
I cant play cd or dvd on my laptop
A DVD player that is an integral part of the laptop does not need drivers to make it play discs. If there is no driver shown, maybe the DVD unit is faulty?
All laptops will play CD/DVD from boot without drivers. The drivers are there to allow you to do specifics to the DVDs.
Aug 06, 2016 | HP Pavilion Computers & Internet
My unit can not write to any cd or dvd. In the nero software it says that the unit has been disabled. How can I fix this? Please write me at aagramont@hotmail.com Thank you very much.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Mar 15, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
Sometimes it doesn't read CD and DVD, often doesn't recognise any CD Or DVD inserted in even its driver. THANKS for helping me!
1. When an optical drive doesn't read or recognize CD/DVD the unit is in need of replacement. Units can be straight out of the box and fail.
check the connection to the device ( cable) and the power to the unit
Mar 13, 2011 | LG GSA-H55N DVD-RAM Burner
Acer Athlon x2 Cd drive won't recognize CD
If the PC will not recognise any CD, re boot the PC with your Windows system CD/DVD in the tray. If it reads the disk, the DVD unit is OK, you probably have a conflict somewhere in the drivers.
Go to Control panel, Device manager, double click on DVD/CD-ROM drive, select the DVD drive, doulbe click and from the menu select Driver. Select Uninstall driver and reboot your PC.
When it boots the PC will look for a new driver and place it where there is no conflict.
Hope that helps.
Oct 31, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
My computer can read cd's but not dvd's the drive is philips CDD5301
you need a dvdrom.cdrom cannot play dvd while dvdrom can play all of them
Oct 29, 2010 | Philips Computers & Internet
My DVD RW AD-7563A doesn't respond when disc inserted. Tried allowing my M-6750 to find a a driver. No dice. Where can I find a driver for this device?
OK, a CD DVD doesn't require any driver, other than the "Generic" driver that Windows installs. IF it will NOT install A/Any Driver. Then the unit has faulted. This is very very common. I get countless CD DVD replacements a year, at my shop. Usually a DVD/CD will "Just Work" 9/10 times if the unit doesn't work, or work correctly, it is the Unit itself. More often that not, it is the Laser Head, or the Quadrant Detector, that faults. CD/DVD's are very simple to replace. It is preferable to get an exactly the same one.However there are many, ones that will work just as well, a CD/DVD is a CD/DVD they are the same for most part, except for the on-board software, differences. .Check all connection, and power as well. Sometimes it is the CD/DVD "Controller" that faults on the actual Motherboard, now, the ONLY way to troubleshoot this, is by replacement, by, swapping out, the unit, for a "Known Good" unit. If replacing in a laptop, you should, indeed, get ab exact replacement, the CD?DVD is held in usually by clips, or screws, underneath the laptop, about at the rear of the unit, simply remove fastenings, slide out the old bad, CD?DVD, and slide in, and press home the connector, on the New one, then reboot the laptop, the BIOS, will "See" the new unit, and the Windows software will "Detect" and install the new dive. It will be ready to use after a reboot.
Apr 18, 2010 | Gateway (5500652) (  5500652)...
Disappearing DVD driver
Use device manager to remove the dvd/cd unit, and then reboot the computer. Vista will locate the unit and install the driver.
It is possible that the dvd/cd unit has failed and requires repair or replacement
Jul 05, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
Cant burn a CD/DVD on the Samsung DVD-Rom SD-616Q
This unit can read most formats, but it doesn't support write operations.
Mar 26, 2009 | Microsoft Windows XP Home Edition
Samsung cdrw/dvd sm-308b
your drive have a problem in CD unit - the drivers with CD and DVD have 4 units (CD Read, CD Burn, DVD Read, DVD Burn) one fail not fail all, your drive can't read but burn a cd, or inverse.
buy a new drive for solve this problem.
Dec 11, 2007 | Computers & Internet
HP Pavilion dv6748us Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
