Question about Panasonic NN-SD797S Microwave Oven
Panasonic NN-P794SFX shuts of after few seconds, but works at times. Have also seen a failure code H98 at times
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Inverter 1200W - NN-SN676S
That code indicates a problem with the magnetron, inverter or control board.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Microwave show H98 in window
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Jul 05, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: my panasonic NN-T945SF starts, runs for a few
Posted on Sep 12, 2009
  • 8909 Answers
SOURCE: H98 ERROR CODE ON A
H98 means that the magnetron or invertor has failed. The invertor is not user serviceable.
Posted on Mar 10, 2011
NN-T945SFX CODE H98 RUNS A FEW SECONDS THEN STOPS
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Dec 24, 2014 | Panasonic Pansonic microwave
Panasonic nn-sn778s microwave shuts off and no heat- H97 is error code
Aug 21, 2012 | Panasonic Genius Prestige Nnsd997s -...
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
May 31, 2012 | Microwave Ovens
H98 ERROR CODE ON A PANASONIC M/W NN-SN797S WHAT DOES THE ERROR CODE MEAN?
Mar 10, 2011 | Panasonic Microwave Ovens
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Hi, I have a Panasonic Inverter microwave NN-Sn9688. It's less than a year old and when you press the START button H98 appears and it will not start. Everything else works, clock etc and reset/stop...
Hi Judith, I am Kelly
If this has a 1 year warranty it is time to make that call.
Otherwise see this link about H97 or H98 codes: http://www.applianceaid.com/micro_faultcodes.html#panasonic
There are a few things that can cause the problem, none of them cheap repairs. The Magnetron filament, Control board and Inverter are the top 3 other than a losse connection.
I tried running the Model number NN-SN9688 and it does not cross. See Panasonic link here: http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832097&Ne=&No=0&Nr=12001&Ns=&Ntk=SupportSearch&URL=vSupportSearch&cmTag=true&catalogId=11017&storeId=15001&cm_sp=SiteSearch-_-SupportSearch-_-SupportHome&Ntt=NN-SN9688&x=28&y=20
I did not go to Panasonic Global and try other countries. I just did a USA search.
Thanks for choosing FixYa.
Kelly
Sep 10, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
The microwave shuts itself off after 3-5 seconds on all cook settings
i have model # nns 977s it shut of and show H98 what is wrong?
Dec 26, 2009 | Panasonic NN-T964SF Microwave Oven
Microwave works for 5 seconds
"h98" INTERNAL ICU FAILURE" main control board has failed . will cost 3/4 of the cost of the microwave itself .......... get a new microwave
Jan 22, 2009 | Microwave Ovens
Panasonic NN-SD797S Microwave Oven Logo
129 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
