Question about Sony Audio Players & Recorders
Sticky knobs How to clean sticky sticky knobs/dials.Have one from back in the 80's
  • 954 Answers
Free them up with wet type contact cleaner or some other suitable lubricant.
Posted on May 08, 2014
    Scholar:
  • 114 Answers
Get some either EUCALYPTUS or TEA TREE Oil... and using a Dishcloth give them a good wipe then rinse the cloth and wipe over again to remove the excess oil.
  • Rick May 08, 2014
    Forgot to mention.................... take care to NOT allow any oil or water into the radio..... turn it on its back or side to do this
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
A LOOSE BATHROOM SINK HOT WATER HANDLE
Is it the whole tap or just the knob/lever?
Whole tap, there is a nut underneath that needs tightening. Don't over tighten it.
Just the knob or lever that you turn to turn on and off? You will find a small screw at the rear. It is a set screw, so it doesn't have a head, it just sits in a hole. Usually a hex key to tighten it. The hole is often filled with gunk so clean it first with an old toothbrush. The set screw is often sticky so undo it I turn before you tighten, lift the knob off, screw the screw in until you see it coming out of the inside to clean the threads. Unscrew the screw back out, replace the knob and tighten it.
Oct 10, 2015 | Plumbing
The button hole knob on my Bernina 830 is very hard to turn. Is there anything I can do to fix this myself?
Do not force the dials, or they could break. I have resurrected some older Berninas whose knobs were totally frozen. The dials usually get stiff when the oil is drying out. Be sure you are cleaning and oiling your Bernina 830 on a regular basis. Use only NEW good quality oil (not 3-in-1, WD-40, or cooking oil). Only one or two drops in each spot per your manual. To help loosen things, direct hot air from a handheld hairdryer into the interior of the machine (direct it toward the buttonhole mechanism). See if that helps loosen things. You should perform regular maintenance on your machine every 40 hours of use or every six months if not in use.
If the dial is still sticky, slowly rotate the dial and study how the mechanics work in the machine and apply a drop or two of oil to the places where metal rubs against metal.
Hope this helps.
Carol--glad you were able to get it operating again. Using +40 yr old oil is probably not the best choice. If the oil is dark yellow or brown, you should discard it as it will eventually become gunky too. You can pick up a fresh bottle from a Bernina dealer--be sure to tell them that you have an oldie (but goodie) Bernina 830 Record to get the correct oil. You can get the dispenser with the long spout to get into hard-to-reach spots. There are other oils you can use (can't remember the specs right now), so unless you want to do some research, Bernina oil will do just fine. (You can join the Yahoo Group for BerninaThirtySomethings where there is a ton of suggestions on oiling, operating, maintaining, and using your wonderful 30-Something vintage machine. There is also a long conversation about types of oil to use.)
If it seems your machine is kind of sticky (difficult to turn the handwheel, or the motor seems to strain to get things moving, etc.), then a good suggestion is to put a drop of oil on every moving metal-to-metal joint. (Slowly rotate the handwheel, the dials, and levers and watch where things move.) Do NOT oil the two plastic gears or the metal cams!!! And, use only 1-2 drops of oil. Be sure to get the 4 or 5 oil holes on the needle take-up mechanism (they look like rotating knuckles) and adding a drop where the needle bar rubs would help. Look for a couple of other oil holes just to the right of the cams that help keep the stitch selector operating, and don't skip the oil hole on the right near the handwheel. Be sure to get the oil holes in the bobbin area (there's usually one on the far back behind the bobbin mechanism next to the case that is difficult to see, and also one on the far right that helps the feed dogs. Once you've hit all the moving joints, you can hand rotate the handwheel to get things distributed. Then try sewing slowly. You should notice your machine runs much quieter and smoother now. Such a happy sound!!!
Once things are moving well, you probably won't need to oil the individual moving joints again unless you notice things are getting a bit sticky again. Too much oil is not a good thing too, so don't over-oil!!!
Cleaning the bobbin area and putting a drop of oil in each oil hole and the hook race is probably sufficient to keep your machine regularly maintained. (The manual does not show all the oil holes, so you might have to look for them. Once you are able to recognize them, they are relatively easy to locate --be sure to rotate the handwheel as some oil holes are not always visible.) Some machines have a red dot to help you locate the oil holes, but sometimes not all of them are marked. (The picture below will help you locate the oiling spots.)
Be sure to run your sewing machine on some scrap fabric after oiling to make sure you don't stain your nice project!
Enjoy your lovely machine! Treat her well (oiling and cleaning), and she will treat you well for many years!f8ddf002-f79d-4ad0-a6d1-deee606a0728.jpg
May 05, 2015 | Bernina Sewing Machines
Dodge Caravan 2004 - Sticky Gas Pedal(Not carpet related)
open up ur throttle body u will find alot of carbon . use cab cleaner to clean it then mount it back it will drive smoothly
Jul 26, 2010 | 2004 Dodge Caravan
Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 model 110
If you are talking about the Cycle Selection knob, turn the washer to an OFF position, or unplug. I can't remember if you need to pull the knob out or leave pushed in, but the knob will come off by turning it counter-clockwise. After unscrewing it and removing, the plastic dial under the center knob will simply pull off. I hope this helps you. If you need further assistance, please let me know.
Jan 15, 2009 | Kenmore 24032\24036 Top Load Washer
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
80 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
