Question about Brother XL-3030 Electronic Sewing Machine
Why won't my needle catch the bobbin thread
I put the bobbin in and try to catch it and pull it up. But it won't catch. I tried to use a metal bobbin. Not a bobbin that is made for my sewing machine. Please let me know if I am on the right track.
This happens to me when i have put my bobbin in upside down (i know sounds nuts) but yes it is possible for it to be in wrong, take it out and turn it over make sure you feed the thread as shown on your machine ...pull the needle thread tight and turn it will catch if its the right way up and threaded right...good luck
Posted on May 08, 2014
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: Thread won't catch bobbin
I hope to God nobody else pays more for a repair than the machine is worth.
It's ridiculous to spend $300 for that repair since the machine is available almost everywhere for way under $200. You could have thrown that one in the trash and bought a new one cheaper than the repair!!
I paid $129 for mine, had the same problem with two, yes, two of them, and sent them back and was sent another which so far is working fine. There seems to be a flaw in the engineering of that machine since so many people are experiencing the same problem. The machines DO have a warranty so please, please, be careful of unscrupulous repair people. Oh, I'm sorry but I need to mention that I bought my machine from eBay and it was a refurbished machine sold by Ken Sewing and Vacumm in Muscle Shoals, Al. They stand behind their products and were very nice to deal with, they even paid for the return shipping on the two that I returned. Hope this helps y'all.
Posted on Nov 10, 2008
  • 12 Answers
SOURCE: Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Posted on Jan 09, 2009
  • 5 Answers
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Posted on May 25, 2009
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
Hello, the thread from the bobbin is not getting out when the needle gets into the metal piece. Is marks stichhes on the fabric, but is does not stitch.
Make sure that when the bobbin is in place that you can pull the bobbin thread with your hand easily. If not, the bobbin may be in backwards or the bobbin thread is not properly routed. Also, make sure that the foot is down when you try to catch the bobbin thread with the needle.
Dec 07, 2014 | Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
My bobbin thread won't pull up. I tried what was listed to do, but it didn't work. Please help me~!!
Here are some things to check:
1. check the threading and tension of the top thread. It may look like it's threaded correctly but not be. When you pull on the thread is there some tension but still pulls out? Make sure it isn't catching somewhere on the path. Also make sure it's not too loose. If it's too loose it won't be able to pull the bobbin thread up enough.
2. check the bobbin threading and tension. Does it have some give but not reel out a ton? Is it catching? Is the bobbin in all the way - hear a click when inserting it?
3. Do you have the right needle for the machine? Is it inserted correctly? Try sewing through ordinary cotton first. Is it stitching? If so then you may not have the correct needle size for what you are trying to sew through.
Mar 31, 2011 | Brother XL-2600
How to thread the singer cg590 sewing machine??
First, be sure your bobbin is in correctly, place it with the thread running counter-clockwise (the tail will be off to the left), and drop it into the bobbin case. Pull the tail toward you and make sure it catches on the silver catch closest to you by pulling to your left then away from you (toward the feed dogs). You should now feel some tension on the thread, this is good.
Be sure the presser foot us up and the wheel is turned so the needle is at it's highest point (neutral), then put a spool of thread on the spool holder (behind the machine above the motor) with the thread catch (a little notch) to the right as you put it on. Put on the thread holder (a plastic donught that holds the spool in place). The spool should not move but the thread should come off of it freely.
Bring your thread through the plastic catch on the back of the machine (near the center) by passing it underneath and pulling upward and to the rear. Pull it to the front over the top of the machine and pass it through the bottom of the small metal holder (not the round part, that is for winding the bobbin). Bring it down in front of the machine to the tensioner, passing it around the bottom of the tensioner then pulling up so that the tension is engaged. Don't worry if you don't feel tension, that's normal if your presser foot is up and needle is at the top. Pull the thread up to the top of the machine and through the receiver then down toward the needle. There is a double loop just above the needle, thread through it then thread your needle front to back.
Be sure to pull up your bobbin thread and hold both threads as you start to sew.
Feb 22, 2011 | Singer CG590 Mechanical Sewing Machine
I cannot get the bobbin thread to catch and pull through the footer wen trying to thread the machine?
Make sure your bobbin is placed in correctly. Thread is counterclockwise as you place bobbin in the metal piece. Pull thread end through sliver in metal piece. Hold on to movable metal latch then lock the bobbin in place. Bobbin should not fall out but is able to rotate. Rotate the wheel on the furthest right of your Singer 1507 machine towards you to move the needle downward. The top thread should then be able to catch and pull up the bobbin thread.
Dec 02, 2010 | Singer 1507
I am having trouble with the thread catching. I have tried combination's of the same thread & bobbin thread in the bobbin. I have changed to the needle. Under the plate I see a tension to the left. It...
if you are using HUS bobbins make sure you have it in the holder with the H facing up and then wind through the 2 small pieces of metal.. Hope this helps!
Jan 15, 2010 | Husqvarna Designer I
Hi I am pretty sure that the bobbin and the thread are in correctly but when I put the material in the needle just put holes in the material. what am I doing wrong?
you may have adjusted the upper tension and made it so tight that the thread just pulls out of the needle and needle makes holes in fabric. you might want to check the feed of the bobbin, it will not allow the machine to sew if it is not able to be picked up by the needle. the bobbin thread is usually (when held in your hand) with the thread coming counter clock wise. and then it will lay in the bobbin holder and the end of the thread will come back to about the slide catch thing and be held there until the needle thread catches it (leave the cover off the bobbin area until you watch and see what happens then. Try adjusting the bobbing tension too hope you understand what I mean here.
Mar 07, 2009 | Singer 7444 Mechanical Sewing Machine
Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Nov 12, 2007 | Kenmore 12102
Sewing Machines Logo
89 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
