Question about Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black
F93 code door locked
This code appears on my rigidaire cooktop even with door open, reset fuse box but no fix. Any ideas???
  • 64 Answers
Have door open and hold door switch
Posted on Jun 23, 2009
What does the F93 code mean and how do we fixt it
i know that it can be very difficult to have issues with your oven. the f93 on this model of kenmore range indicates that you have a problem with the oven door lock assembly (see image below). this can be caused by a failed oven door lock assembly, a wiring failure or a bad electronic oven control board.
i recommend that you unplug the range and check the wiring between the components first. you can remove the upper back panel of the range to access the electronic oven control board in the console. you may need to remove the lower panel to access the door lock assembly on the back of the range. the image below shows the wiring diagram and other information that should help you check the wiring connections. check for a mechanical binding of the door lock assembly as well. if the wiring connections are okay, you will likely need to replace the oven door lock assembly. if you need further assistance, please reply to this thread. thank you for using manage my life.
May 23, 2015 | Kenmore Elite 30" Slide-In Gas Range White
How i can stop the fan and open the (locked) door (error F93)model Frigidaire CGEB27Z7HB
Hello Yves Trottier, thank you for your post!
I understand that your Frigidaire range is displaying the error code "F93". Typically, "F93" stands for maximum over door unlock time exceeded. This could be a potential issue with EOC (Electronic Oven Control), motor door latch assembly, or fan motor. I would recommend performing a reset on your range which consists of you disconnecting power from the range for approximately ten minutes. If you continue to experience such issues I would suggest consulting with a professional technician for proper diagnosis and repair. Hope this information is helpful. -Matt
Dec 06, 2014 | Frigidaire Kitchen Ranges
My Kenmore Elite oven door is locked and I am getting an F93 error message. I have had repairmen here 3 times already to fix the problem. Can you help?
The F93 - Maximum oven door lock time exceeded. First thing to try is holding the clear button down for 3-5 seconds sometimes this unlocks the door and then leaves the loc light still on in this case you would open the door and once again hold down the clear to make the loc light clear. If your unit doesnt have a clear button then you would hold the stop button for the same amount of time as described above. If this doesn't work try shutting off the power at your electrical breaker for 7 minutes this usually causes the control to reset in the unit. If you have any further questions or if this does not work to allow you to be able to open the door and clear the error code message me back for further diagnosis. Thanks
Rick
Sep 03, 2011 | Ovens
Have a kenmore stove, and a code of F93 is coming up. What is the solution?
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
Jul 19, 2011 | Kenmore Ovens
Error F93 lock out of the oven how do i reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 30, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
F93 error. Oven door is stuck, won't open. Display is flashing door locked and continues beeping. This happened once before and a repairman had me press a few buttons and it reset and fixed the...
Hi
Thanks for using FixYa. F93 code means "Maximum oven door lock time exceeded." Actually it's trying to lock the door but is not aware of the time to stop. Please check the micro switch and lock’s motor. Replace whichever has gone bad. To reset it turn it off for more than 10 minutes and then turn it on.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F93 error
F93 error code means Maximum oven door lock time exceeded. Check oven door lock/door lock switchs.hope this helps
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
F93 fault code
unplug the range.
wait 1 minute.
wait 2 minutes.
Oct 04, 2008 | Frigidaire FGF326AS Gas Kitchen Range
OWER OVEN DOOR LOCKED WHEN WE TRIED TO USE THE SELF CLEANING OVEN AND THE CODE F93 ERROR APPEARED
F93 is "Maximum oven door lock time exceeded."
Basically it's trying to lock the door, and doesn't know when to stop.
This could be a lock motor problem, or a faulty microswitch.
Turn off and wait 5 minutes. Turn on again, and pull and push the door continuously for 30 seconds or so. Turn off again.
You will need to test the switch and motor assembly. Replacing whichever is defective.
Hope this helps you.
If you get it sorted, please rate as Fixya.
If it was of any use - as helpful,
If no help- as thanks F T.
If no help at all - inappropriate.
(I think the descriptions are missleading.)
Thanks.
Jun 14, 2008 | Frigidaire Kitchen Ranges
Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Logo
370 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
