Question about Schwinn 26" Mens Cruiser Bicycle
How to fix my 20 " rear axel - Schwinn 26" Mens Cruiser Bicycle
  • 957 Answers
What is wrong with the rear axel? you didn't say in your post.
Posted on May 09, 2014
Diagram for VW sand rail rear hub axel
Hi. What rear axel type do you have? Is it a 1975 beetle hub?
May 05, 2014 | 1975 Volkswagen Beetle
99 mustang rear tire bent inward?
Does the mustang have independent (IRS) axel or the solid 8.8 rear axel?
Jun 12, 2017 | 2000 Ford Mustang
I have an 18v Milwaukee bandsaw (model #2629-20) and the blade is constantly slipping off the wheels. I'm thinking it's an easy fix but not sure exactly what is causing the problem. Please hel
Possible causes:
- Tires: If the tire(s) on the front or rear pulleys are worn, torn or have chuncks out of them, the blade can slip off.
- Pulley(s) out of line: If either or both pulleys are out of alignment the blade will work it's way off. This could be caused by a worn pulley hub; a worn or broken pulley axel; or worn, broken or frozen bearings where the axels turn. On the drive pulley this could include the bearings on the drive shaft or the boss where the bearings fit into.
- Blade: If there are any kinks or slight bends in the metal they could cause the blade to work off the pulley.
Mar 07, 2012 | Milwaukee Tool Saws
1992 ford f150 speedometer quit working and ABS light is on, also odometer is not working
where the speedometer cable goes into the transmission under the car, when removed from the trans there is a small gear that gets worn out over time.. that little gear or the entire speedometer cable needs to be replaced. An easy and inexpensive fix. I believe the ABS light is on because the computer needs the speed of the car to make its calculations for braking. As long as the speedometer is not working, it cannot do that. So after the speedometer cable issue is fixed, that issue should be fixed as well.
Mar 25, 2011 | 1992 Ford F150 SuperCab
I have a 1995 cadillac deville sedan 4.9 it seems as if the back end of the car has lowered and is lower then the front of the car what should be the problem?
The rear height sensor may have disconnected from the axel. The height sensor is mounted to the
body above the axel and it has an actuator arm thats connected to the center of the rear axel.
When the body comes down the arm go's up, this engages the compresor and inflates the suspension to a preset height. Start with the compressor, turn the key on and you should hear the
comp. run for about 10-20 seconds then turn off. If it won't turn off check for air leaks. But if it works
normally, check the power+ground connections and the actuator at the height sensor.
Hope this helps.
Nov 19, 2010 | 1995 Cadillac DeVille
I have 2001 Chev Tracker, Oil started to run out of the Right side break drum. Removed Drum and foud oil all over the breaks. Tried to remove the Axel by removing the four nuts off of the backing plate,...
fror fixing the brakesw take the other rear wheel off and duplicate what u see. to get the axel out u must first remove diff cover in center of rearend then u will see a clip for each side axel remove clip and axel will slide out. good luck fron 1 to 5 being difficult its a 3
Jul 21, 2010 | 2002 Chevrolet Tracker
How to remove rear axle 03 chevy silverado
You will have to remove the rear end plate off of the back of the rear end. Then turn the carrier untill you see a big silver pin that goes through the spider gears. Those will be 4 small gears in the rear end carrier. If you look at the right side of the carrier were the pin goes through it you will see a small bolt head, That bolt goes through the carrier and holds the pin in place. Remove that bolt then reach up in the rear end housing and push the pin towards you untill it comes out. ( DO NOT TURN ANYTHING AFTER YOU REMOVE THE PIN) are the spider gears will fall out.
Now get someone to push the axel in while you are looking at the 4 small gears in the housing, when they push the axel in a C-clip will fall off the end of the axel and into the rear end, You will see it fall out. Then just pull the axel out.
When you put the axel back in, push it all the way in then slide the c-clip over the end of the axel and then pull out on axel and that will hold the clip in place untill you put the big long pin back in the carrier. I hope you understand, just watch what you are doing. GOOD LUCK.
Oct 09, 2009 | 2003 GMC Yukon
85 cj7 rear axle removal
Do you have bolt in axels? or are they held in with C- clips? If its bolt in axels you need to remove the bolts, and you may need an axel puller to get them out. If its got C- clips rear cover on rearend has to come off, and pin has to be removed to get C- clip out to get axel out.
Apr 03, 2009 | 1986 Jeep CJ7
How do I change axel bearings on jeep GC ltd. 5.9? Need a step by step for this procedure. My right rear makes noise when I turn the wheel all the way to the right and go in reverse, almost like a binding...
Job is not terribly difficult, but instructions are too long to re-write them. Get yourself a haynes manual (about 20 bucks) and it will guide you through the job. If you need any help along the way, I'll be glad to help! (manual will help with lots of other stuff as well!!
If you have the setup I'm thinking of, make sure you buy a new diff cover gasket and gear lube along with axle bearing.
good luck
Mar 14, 2009 | 1998 Jeep Grand Cherokee
Rear wheel axel Ford F150 2002 how do I dismantel it to check if it is a bearing, making a clunk sond , parked as it has gotten, worse. I have very little money and I would like to fix it myself.
check for a propshaft UJ worn first vehicle up in air wheel free then grasp front and rear of each joint in turn and give it twist ,iam pretty sure this has gone and not the pinnion/crownwheel.
Nov 18, 2008 | 2002 Ford F150 Regular Cab
Schwinn 26" Mens Cruiser Bicycle Logo
48 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
michael
michael
Jim Goldsmith
Jim Goldsmith
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
