Question about Quantum Edge 6 Wheelchair - Used Electric Wheelchairs
If it cant be reset how do i get it to go forward it does everything else it goes backwards and up and down but not forward and the scooter store went bankrupt so noone answers the phone
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 58 Answers
If a dealer has gone out of bussines you can ring the manufactor and ask them, they should support you in ammending your issue.
Posted on May 08, 2014
  • 130 Answers
Disconnecting the battery for 15 minutes will reset. But, its probably the joy stick. You can try to take apart and clean the contacts but, you probably will have to replace it or the board.
My reverse goes faster than my forward what's wrong
Sounds like the throttle is connected backwards. The parking brake maybe hanging up. if the scooter is run for 10 mins forward, then carefully check with your hand that the parking brake is warm and not hot. Hot indicates brake slowing you down and making the motor work too hard. For other answers to Scooter Problems goto my free app.
Scooter Doctor App
Aug 07, 2015 | Elite Pride Go Go Traveller 3 Wheel
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
Older Shoprider 778b goes backwards when key is turned on, what's up? Check all connections.
The throttle set screw may have slipped a bit causing it to be a little bit on so when you turn the key on it moves forwards or backwards loosen and reset throttle bar and it should stop doing this.hope this helps Richard
Jun 22, 2013 | Shoprider Sprinter Xl3 Deluxe 778XLSBN
My scooter is too slow,the battery charges,but it only drives at very slow speed,while going backwards it goes fast.Can you tell me what to do?
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. In the future give as much info about the scooter as possible.
1. Replace the throttle pot and or the speed pot.
2. Sometimes even batteries that take a charge are not strong enough to run the scooter. Have them load tested at an auto parts store to make sure. If you have bad batteries that will make you scooter do what you say it's doing. Don't forget your reverse speed is only 1/2 as fast as the forward speed on all scooters.
Good Luck
Tim
Apr 30, 2011 | Health & Beauty
No forward, only backward
Hi. If the light flashes 7 times, it has a speed controll fault. It might be the throttle lever ( wig wag ), or it might be the speed pot that controls your top speed.
Try moving the throttle lever ends up and down while you are driving the machine. Doing this wont fix it, but it will highlight the problem, if the throttle lever is faulty. Also try moving the speed pot back and forward a few times.
Good luck. Neil.
Jul 17, 2010 | Pride Mobility Products Hurricane PMV...
No drive in forward or reverse
Check your brake Mechanisim if you can push it manually the you need to reset your brake. It will not move unless your brake is locked.
Mar 05, 2010 | Health & Beauty
Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Feb 24, 2010 | Health & Beauty
Scooter won't move forward or backward
go to electricscooterparts.com get a rear wheel clutch assemly fixed ours!!
Jul 25, 2009 | Cycling
Quantum Edge 6 Wheelchair - Used Electric Wheelchairs Logo
Top Quantum Health & Beauty Experts
Scooter Doctor
Scooter Doctor
Robin Hill
Robin Hill
Are you a Quantum Health and Beauty Expert? Answer questions, earn points and help others
