Question about Electric Earthwise Corded Lawn Mower 20in. Deck
Bearings burned up on my earthwise tiller/cultivator model tc70001 where to find replacment bearing
  • 130 Answers
Try some of the dealers on EBay.
Posted on May 08, 2014
Cherpping noise
check the belt adjustment and the oil level in the gearbox
Apr 17, 2012 | Husqvarna 205cc Front Tine Tiller
Hahn Eclipse Tiller Worm gear Bearing.
there should be a number on the inner race just enter that number on google search
Mar 25, 2012 | Garden
I need to replace the wheel on my tiller, The pin is out. The wheel won't budge
Try using some WD-40 between the axle and wheel bearings. Let it sit for a while and then try again.
Aug 03, 2011 | Mtd Garden Tiller (Mtd)
When I start my tiller, it starts and immediately starts making a loud screaming sound.
The problem you are having is coming from the ratchet bearing located under the pull start housing. Remove the pull start housing, then take the screws out of the screen then put the screws back in the ratchet bearing after you remove the screen. Then remove the ratchet bearing by unscrewing it from the crankshaft. It' best to replace this part and be sure to lightly grease the shaft before you put the new ratchet bearing on and this will solve your problem.
May 02, 2011 | Briggs & Stratton Garden
Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Apr 06, 2010 | Honda 25cc 4-cycle Mini Tiller
The tines don't want to turn motor runs great
You may have a clutch burned up. The transmission may need replacing.
we had one in the shop earlier this year and the same thing happened to our customer. We tore it down and found some gears needed replacing but Honda does not sell the parts separately. You have to buy a new transmission. And they run about $300.00 USD. Check with your local dealer, see what they might be able to help.
Dec 15, 2009 | Honda 25cc 4-cycle Mini Tiller
Over filled with oil. Cranked and ran for a short while then stopped. Drained oil and refilled with 3/4/qt fresh oil. Tried to crank but rope to hard to pull.
Unfortunetly you may have spurned an iternal bearing, depending on the type of tiller, If it is hard to pull something is hanging up, seal or bearing on the "cam" will do that, if the oil pressure was enough, or the bearigs were older and worn.
Apr 30, 2009 | Yard Machines Garden
How do i change ball bearings on tiller shaft
Hello mikeant2:
Usually Heat and a Press/Puller are Required to Remove the Bearing from the Shaft. Sometimes I have even had to Cut the Bearings Off with a Die Grinder.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Apr 18, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Electric Earthwise Corded  Lawn Mower 20in. Deck Logo
89 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
