Question about Ovens
Whirlpool oven oven wont come on ,just installed new igniter
    President:
  • Ovens Master
  • 1,922 Answers
Did you replace the gas thermocouple or just the ignitor?its probably the thermocouple
Posted on Jul 29, 2009
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool oven wont start, is there away to light the pilot?
You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
Anyway, that's where I'd start.
Nov 04, 2014 | Whirlpool Ovens
Gs445lems wont ignite
The oven valve can be the problem if the coils in the oven valve are bad, even if only one side of the valve is bad the bake and broil will not work. If I remember correctly there should be somewhere around 50 ohms across the coils. if it is much more or much less this is probably the problem.
Mar 16, 2014 | Ovens
The broiler and the burners all light but the oven doesn't.
your oven igniter is no good. remove racks from oven, unscrew the 2 screws in the back of he bottom panel. remove panel. there will be a metal plate on top of the flame spreader. remove the wing nut holding the plate and remove plate. you should now see the igniter. now try turning the oven on. after a few seconds you should see the igniter glowing. if it gets to a real bright then it is good. if it doesnt it is bad. unplug the stove.changing it is fairly simple. just remove the 2 screws holding it in place, gently pull on the wire to see if there is a connector, if not then you can always cut and join the wires to install the new igniter. igniter should run you less that $20 bucks. its pretty simple to change. after changing the igniter and before reassembling your oven, just plug it back in and turn the oven on. oven should lite. do not put hands or ace inside the oven while attemping to lite.
Feb 02, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
My oven wont turn on but the broiler works?
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 13, 2010 | Whirlpool SB160PEE Gas Single Oven
Oven wont come on, installed new igniter
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve/coil assembly
Jun 22, 2009 | Whirlpool Ovens
Door wont shut and the light stays on
Since this is a new install, check around the perimeter of the oven door and see if it is closing all the way flat against the surface. The hinge could have partially popped out and needs to be reset. Can you tell if the oven door is popped out at the top portion of the oven door or the lower portion of the door?
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Whirlpool RBS245PDS Electric Single Oven
Oven will not light
I have same the problem, what is the solution,
Nov 17, 2008 | Whirlpool SB160PEE Gas Single Oven
Ovens Logo
62 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
