Question about Pioneer SD-643HD5 64" Rear Projection Television
Pioneer sd-643hd5 Hi, I am having the same problem with my pioneer sd-643hd5 tv. The fuse keeps blowing ,the one in the middle. I changed it a few times and it would eventually blow again. However after reading one of the posts that said it was a 5 amp fuse I realized I was using a 4 amp fuse. So anyway I replaced it with a 5 amp fuse and it seems to be working fine. I am a little worried now wondering if it is the right fuse and if my set is going to blow up or worse catch fire. I will be unplugging the set for now until someone can tell me if it is the right fuse or not. Thanks for any help.
  • GregShires Dec 19, 2007
    I have a fuse problem too. I removed a 4amp fuse so I replaced it with a 4amp fuse and it blew as soon as I turned on the TV. Should I go to a 5amp? Is there a special 4amp fuse to use. Now it doesn't even go to on for 2 secs, it just stays in standby. Did something else break?
  • dizzyone Dec 19, 2007
    Hi I am not an expert but I did replace the middle one with a 5 amp after going through lots of 4 amp slo-blo fuses. It has been about 1 and 1/2 months so far and no problems. I don't know if it makes a difference but I only shut the TV off with the remote and it goes in standby. Good luck
  • 4,402 Answers
Sony Convergence
Posted on Jan 25, 2008
  • Marten Salazar
    Marten Salazar Jan 26, 2012
    Where did you buy the fuse?
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
My TV will not come off of standby?
You have a blowed Fuse 6.3amps ,Located in the middle of the power supply board where the FBT flyback Transfomer is. or you need to replace the STK ICs - STK392-110s use 120s,150s 180s. Mats Electronics has them 1-800-628-1118
Nov 17, 2010 | Pioneer SD-643HD5 64" Rear Projection...
I have a Pioneer SD-643HD5 that was working and then just turned off? Now the tv won't turn on
CK for Blowed Fuse will be in middle of chassis 6amp fuse if it is blowed set will not come on.
Dec 30, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Tv only stays in standby mode
Replace Fuses 302 5amp and 303 5 amp Resolder all poor connection on power supply board and Replace Both STK ICs they are big black ics STK392-180s is best ICs Call Mats 1-800-628-1118 This should have you back to watching TV again.
Sep 19, 2009 | Pioneer SD-643HD5 64" Rear Projection...
My pioneer hd683 will not turn on. It may be that I need to replace the stk392-180. How do I troubleshoot to determine if this is the case. And if so, how do I replace these parts?
Thats a good possiablilty STKs but first CKL a 6amp fuse it will blow and shut tv off its on power deflection board in middle of chassis near right side if it is OK the replace STKs for parts call Mats 1-800-628-1118
Sep 18, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer sd-643hd5 fuse issue
The fuses may not be your problem--I have fixed several of these---The large power board is on the right side as you look from the back?
Lots of these sets develop bad solder connections on that board--several sites on the internet offer to have you remove and send them the board to resolder--this set used lead free solder and after some years has problems--a few I have opened had clearly broken solder joints--I usually in this case remove the board(mark all the many plugs and make a diagram) and solder almost all of it by hand----usually fixes this kind of trouble.
I do this here for free so if this information was helpful give me a vote here....I am here to help people.
If you have any questions or need advice reply to this posting here.
Sep 12, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Aug 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
294 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
