Question about Moultrie Cameras
How do I correct a sd card error display
Display says sd error
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 58 Answers
You may have to format the card using a pc/laptop, if the laptop picks the card up then format the card using FATx or FAT32 do not use NTFS for cards (you can use it but not recommended if using it in various electronic devices) if the card wont format then its simply faulty and a new one is needed.
Posted on May 09, 2014
How do i fix module authentication has failed error sc 866 on Ricoh Mpc 3002
SD card authentication error
A correct license is not found in the SD card.
? SD-card data is corrupted.
1. Store correct data in the SD card.
Feb 10, 2016 | Ricoh Aficio Office Equipment & Supplies
I bought a new SD card and put it in and the screen display keeps sayd SD card error. Please help.
If you're using an SDHC memory card, the camera doesn't support it according to the specs. If it's the correct card, try another one - you may have a bad one.
Feb 15, 2011 | Vivitar ViviCam 3746 Digital Camera
Ricoh aficio 2090 gives sc 866 when i put sd card for work as printer and scaner
SC866 B SD Card Error 1: Confirmation
The machine detects an electronic license
error in the application on the SD card
inserted in the controller slot when the
machine is powered on.
The program stored on the SD card contains
electronic confirmation license data. If the
program does not contain this license data,
or if the result of the check reveals the
license data in the program on the SD card is
incorrect, then the checked program cannot
execute and this SC code is displayed.
• Required program missing or
incorrect
• Download the correct
program for this machine
onto the SD card.
SC867 B SD Card Error 2: SD Card Removal
The SD
Jul 03, 2009 | Office Equipment & Supplies
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3340 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-2300 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-2 Digital Camera
Error 50
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Cameras Logo
157 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
