Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
How to put the spring back into a fl1500le featherlite leaf blower need a online diagram
4 Suggested Answers
spekgt
  • 60 Answers
SOURCE: willnotrecoil
Hello . First thing is remove the starter rope and check to see if the flywheel turn by hand . If turn by hand you have a bad recoil starter , if does not turn by hand the piston is seized . Remove the spark plug and put 2 or 3 drops of oil (2stroke mixing oil) on the spark plug hole and try to turn it again by hand . If still does not turn you have to replace the piston and maybe the cylinder .
Hope this help
Posted on Aug 29, 2009
SOURCE: replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
Posted on Jun 28, 2010
SOURCE: How to get the spring & starter rope back
easiest is to take a slotted screwdriver, poke into the underside air intake and rotate the wheel a bit...usually the rope goes right back in...if not take the three screws out and release the rope.....while your there give it a few twists to loosen it up....you will do this soon enough when the rope breaks :)
GG
Posted on Sep 20, 2010
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
May 09, 2010 | Garden
How to repair spring starter on FL1500LE
The casing is situated so the spring faces the starting spool. The spool is plastic and the rope is wound around it. The hook goes to the spool. Put it back together carefully! Good luck...Lee
Nov 24, 2009 | Poulan Featherlite Gas Blower, with Low...
How to get the spring & starter rope back together on a weedeater featherlight leaf blower. model #FL1500LE
GG
Nov 05, 2009 | Poulan Featherlite Gas Blower, with Low...
The handle has broken where it screws in at the front. Where can I get a replacement handle or get it fiwed?
You can order a replacement handle from the Poulan Parts Store online. Here is the link for you: http://www.partstore.com/Model/Electrolux/Poulan/FL1500LE.aspx
The handle, part number 530054429 is the sixth item on the list at this link. It sells for $7.95
Hope this helps you.
Oct 25, 2009 | Poulan Featherlite Gas Blower, with Low...
MY ROPE WONT GO BACK IN?? HOW DO I SOLVE THIS PROBLEM..THANK YOU IN ADVANCEITS ON A WEEDEATER FL1500LE
well, either the screws that hold the plastic on (thats hooked up to the rope) are loose, or the spring in the recoil is wedged, missing, or dislodged. Might want to take off the recoil and check for any missing parts, wedged in or dislodged. if none of these is the case, try asking a person at your local hardware store, (home depot, westlake, strausser, harbor-freight, Lowe's)
Jul 10, 2009 | Poulan Featherlite Gas Blower, with Low...
Willnotrecoil
Hope this help
Apr 16, 2009 | Garden
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
364 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
